blackbox z axis issues
Discussion in 'CNC Mills/Routers' started by chuck english, Jun 22, 2021.
  1. chuck english
    Hello all, and thanks in advance for help.
    I am using a blackbox to control my mill. I was moving the mill around to set zero, and I lost the ability to control the z axis. I was still able to use x and y. I checked wiring and didn't see anything noticable. I restarted the blackbox cutting the power off to it. Started it back up and the z axis worked fine. Cut out a piece of ply wood and the z axis was way off. I was all the way through a 1/2" piece of plywood and the control z axis read -.24. I tried adjusting the z and nothing. I tried restarting the blackbox and it worked fine for a few minutes and then I lost control again. As soon as the blackbox is turned off and back on I have control again of the z axis..... The x and y seem to be working as they should. Any ideas?
    Thanks!
    P.S. It shows on the openbuilds control software that the z axis is moving, but I don't get any physical movement when it isn't working
  3. chuck english
    MonkeyNutts likes this.
  5. MonkeyNutts
    I've had this several times over the last couple of jobs, where mid way through cut Z stops responding to up/down movement and drags bit across workpiece, luckily not damaging beyond repair. This is really helpful, now I can investigate further when it happens again.
    If you don't have the LED, its then probably an intermittent wiring break/loose terminal: docs:blackbox:faq-identify-motor-coils [OpenBuilds Documentation] - either one of the two, so you know about both
  7. chuck english
    Thanks Peter, I did have the fault indicator light on. I reduced the z adjustment screw to keep it from over heating. It has not given me the fault indicator any more. However, now my z axis is not working properly. If I send a job from the open build control, and I am trying to step down .06 with each step down, it is actually going down about double. It reads -.06 on the open build control, but the actual measurement is more like .12. I tried recalibrating my z axis and it was spot on when I tried to recalibrate. X and Y seem to be working as it should. Any ideas? Thanks!
  9. chuck english
    I just ran a different design through. It appeared to be cutting correctly it was dropping about .06 with each pass and the next thing I know the bit was back up almost at the top of the design and the control said it was -.5. I checked wiring and everything looks to be fine. I can try adjusting it back up some.
  10. MonkeyNutts
