C-Beam™ Machine - Plate Maker
  1. David the swarfer
    remove the tool change command 'T1 M6', GRBL does not understand that.
    you may want to try SketchUp + SketchUcam - very good at generating GRBL friendly code (-:
    (for RTFM and watch the videos!)
    http://www.phlatforum.com/xenforo/threads/sketchucam-download.3128/
    once you know that the machine works and what the Gcode that works looks like, you can tune your Aspire postprocessor to do it right.
    Fety Mann likes this.
  2. shugster
    shugster New
    Thanks David! I will definitely be having a look at those.:)
  3. R_B
    R_B New
    I've been playing around a bit with the noise issue.
    Molten lead filling ? I didn't try that (YET).
    I agree that a lot of it is probably coming from the "ringing" of the extrusions.
    I expect to stick a lot of neoprene on the backs of the extrusions this week.
    If that helps I will probably do the sides of the Z beam.
    X and Y have exterior rollers, so I can't do those.
    Neoprene as in "wet suit material".
    If that doesn't help this will quickly become a garage machine, not a hobby room toy.
    3D printer is the quiet standard around here )-;
  4. motopreserve
    motopreserve Well-Known
    I put some thin pieces of dense neoprene sheet cut to size under the extrusion corners. Then I screwed the whole machine to the plywood top of the stand I built. That way it compresses, not fully but about 3/4 compressed, which the rubber needs to provide maximum vibration absorption.
    I'm not sure I would say it's dead quiet, but it definitely operates with less volume this way.
    Bob R, Serge E. and Joe Santarsiero like this.
  5. Joe Santarsiero
    Joe Santarsiero OB addict
    I'm teasing. I figured you hadn't fine tuned it plus the camera mic plus whatever it is sitting on was making it that loud. Cool that you have a misses that is software savy. Mine just wants to hand me a bunch of drawings and tell me to figure it out. :(
  6. Flash22
    Flash22 Well-Known
    tweak the feed rates on the xpro - it makes a vast difference to the sound level - you can almost get it to sing #cncmusic
  7. shugster
    shugster New
    I know m8, my next door neighbour already thinks i'm right out of one flew over the cuckoo's nest, one day i'm trying to fly a home built helicopter in my garden next a hiller style flying platform, now he's hearing weird noises coming from my living room:ROFL:
    My small garden shed is full to capacity but if I can't dampen the noises down i'll have to squeeze it in somehow.
  8. shugster
    shugster New
    Thanks for the tip
  9. shugster
    shugster New
    I'm quite lucky the misses helps me a lot, she's the brains in this family.
  10. shugster
    shugster New
    Just a suggestions she made this morning .....why not put expanding foam in the holes of the aluminium, messy business but it would probably dampen that chinning noise a bit.
  11. Flash22
    Flash22 Well-Known
    I run out of space a long time ago, having to have a reshuffle to get the cnc gear in
    well the C-Beam has grown - still a lot more to do but......
  12. shugster
    shugster New
    That looks fantastic m8! Keep a note of all the changes with parts list etc encase someone else wants to upscale like yourself, I might at a later date but not for a while.
  13. Davey Rance
    Well i hope that this next weekend when i get back home i can finally get my plate maker working again. It was working and then it had a close encounter with an opening garage door and ended up in a twisted mess on the floor.
    I can confirm that the little nubs on the cast corners if put under a sudden large load (Weight of router falling on it) then they just dig in and make dents and come loose.
    So after filing all of the nubs offs and having to replace all of the 10mm screws it is nearly ready to go again. (Also i put a couple of more corners in just for good luck :) )
    motopreserve likes this.
  14. R_B
    R_B New
    I have no solid theory to support this, but I think most of the "ringing" is coming from the edges of the extrusions, not the enclosed pipes/chimneys.
    I'm probably basing this on some old-time air cooled engines.
    Almost any spongy rubber inserted into the slots that aren't used for wheels would probably help.
    I thought of elastic shock cord, ("bungie" cord) but there is a LOT of linear meters to muffle on just the X Y and Z beams.
    Ahhh, the details, the WRETCHED DETAILS.....
  15. shugster
    shugster New
    ouch!
  16. shugster
    shugster New
    you could be right about that, i think these cnc machines are all noisy to an extent, most you tube videos add music so there is no noise from the motors etc. this is my first cnc machine so its hard to judge with nothing to compare it with. all that said, when the router/spindle is running and hoover, i don't think it will be all that noticeable but the less vibrations the better.
  17. shugster
    shugster New
    send some of that neoprene over my way and i'll roll it up and stick in my ear holes, problem solved! :ROFL:
  18. Brian Mahoney
    Decided to join the fun, just ordered a kit from http://ooznest.co.uk plan to use a smootieboard and a 400 w brushless spindle.
    Ryan Lock likes this.
  19. shugster
    shugster New
    Good stuff! I look forwards to seeing it come together
  20. Davey Rance
    The steppers are noisy. I was planning on swapping my x and y before the accident. After it was a must do as lugs were broken on the steppers so i could no longer mount them.
    The cleathpath servo's are silent for moving things around. Then when you turn the router on it dosnt matter as that makes so much noise anyway.
  21. shugster
    shugster New
  22. Mark Carew
    You could try setting your boards jumper steps settings to say 1/16th or 1/32 if your controller will do it and see if that smooths things out. Remember you will have to change your steps per unit in the software settings to reflect these changes on the board.
    You can use one of these steps calculator to get the numbers your after http://www.openbuilds.com/resources/joseph-prusas-reprap-calculators.3/
    Just received a mail today from a Builder who had mentioned and great idea on using rubber shims on his build and it worked great for him.
    Here is what he said
    May not work for this application but for such a low cost its worth a try.
  23. R_B
    R_B New
    Astrosyn dampers seem to be the standard isolators on 3D printers for the NEMA 17 motors, but they are typically mounted ON plates (of melamine or aluminum), not on long spacers.
    Two diagonally opposite screws attach the motor to the isolator, the other two diagonally opposite screws attach the isolator to the plate.
    The shaft pokes through, to the pulley & belt.
    I'm already a bit uncomfortable with the NEMA 23s being mounted on only 2 (adjacent) corners.
    I will be cutting some new end plates as soon as I have 1/2 inch aluminum cuts going nicely enough - - "as soon as"; ...Yeah, right.
    THEN I might try some astrosyns.
    #443 R_B, Sep 28, 2015
  24. Mark Carew
    Agreed, astrosyn dampers would not work here. What was mentioned above is to try and place a plain old rubber washer between the motor and standoff to help lower motor noise on the frame. Also there's really no need to feel uncomfortable with the 2 mounting holds for the steppers as there are not direct forces other then the stepper motor torque, which I don't think will be bending the mounting screws anytime soon :)
    I do think if the motor noise is a problem then its worth giving the rubber washers a try, but before this I would suggest to set a finer scale on the steppers first.
    As @Davey Rance says above
    is so true :D
    I usually set up my job, watch it run the first pass so I am sure that its working properly and then leave the room and let it work. I will check in on it from time to time until its complete.
  25. shugster
    shugster New
    Thanks m8, I'm not keen on changing settings but if it comes to it i will, i'll mess about and see what i can do, i wanted to lift the machine in the air while its going to hear the difference
  26. Davey Rance
    @shugster yes those are the servo's. Required a different power supply and some extra control wiring but they reduce the noise by about 100%.
    Once i get my stuff together i will try to see if i can do a video to show the difference. But again it is all pointless as when you turn on the spindle / router that makes so much more noise or at least mine dose :)
  27. shugster
    shugster New
    I look forwards to the video, I'm really thinking about vibration, if there is any through the tool then it might become a bigger problem than any noise issues.
  28. roger25b
    roger25b New
    Hi Mark,
    I am a complete newbie to CNC but would like to know if there is or will be or could be a C-Beam machine bundle with an 18 inch square working area?
    Roger
  29. Flash22
    Flash22 Well-Known
    its openbuilds so you can build anything you can think of its a bit of a learning curve but there are plenty of vids and info about
  30. Serge E.
    Serge E. Veteran
    One way to make the machine taller, given it already has about 6" of Z, is to mount the 'table' lower, thus increasing working depth from 1.25" to whatever you can squeeze out with minimal changes. Of course, this is talking theory. I will soon be able to see for myself ... stay tuned. Should be able to get an extra 1/2" or so of working depth just reworking how table mounts ?
