C-Beam Linear Activator
Discussion in 'CNC Mills/Routers' started by Joseph Casalino, Mar 16, 2022.
  1. Joseph Casalino
    I plan to build a C-Beam Linear Actuator to mount on top of my CNC Milling Machine table in order to lengthen the X-Axis travel on the machine. My present mill has a 15" X-axis travel and I need to drill multiple holes for a 36" distance. I am going to mount a stepping motor on the unit that has the same specs as the one on the machine. I will build a control box will allow me to choose which 'table' needs the input. The ball lead screw on my present machine is 5 turns equal an inch. So, I will need to use the same one on the unit. The machine manufacturer has said that it should work fine. As long as I match the spec of that ball lead screw and motor on my kit? How do I do that.
    Thanks,
    Joe
  2. Joseph Casalino
    Well, after consulting with the tech, I found that I cannot modify the kit to use my components. So, I have decided to use the kit just as it is. Besides an interface controller what else to I need to make up a working unit?
    This way the auxiliary table and the CNC table will both move independent of each other.
    Thanks,
    Joe
    Interface is the "user interface". You also need a BlackBox (docs.openbuilds.com/blackbox), a power supply, an Xtensions Limit switch for homing and some wiring
  4. Joseph Casalino
    Can I get all that from the openbuilds store?
  6. Joseph Casalino
    Peter- Thanks for all info. Is there any place than I can see the actual dimensions of the kits and the components?
    Joe
    Sketchup CAD models here: OpenBuilds | 3D Warehouse
  8. Joseph Casalino
    What is the average wait time on the Interface CNC Touch?
    Thanks, Joe
  9. Peter Van Der Walt
    Store related queries (orders, stock levels, wait times,shipping and warranty) are handled by the Store team. Open a ticket on Support > new ticket to talk to the Openbuildspartstore.com team
  10. Joseph Casalino
    The openbuilds interface input. Can you input g-code directly into the interface with a USB drive? In what 'file type' does it need to be. My mill needs a txt file.
    Thanks,
    Joe
  11. Peter Van Der Walt
    Yes, plain Grbl compatible Gcode (gcode is just a text file containing specific commands)
