Calibrate XYZ probe plus?
Discussion in 'General Talk' started by Rhett E, Jan 5, 2022.
  1. Rhett E
    Rhett E Well-Known
    I'm getting my Z dialed in and I've got the steps spot on. I'm finding the probe plate measures at 9.08mm and I'm getting a repeated variation of .08 when manually zeroing Z. Is there somewhere I can calibrate this? I'm assuming it's supposed to be 9mm. Thank you
  2. sharmstr
    You can change to a "custom probe" in the lower left hand corner of the probe screen. After that, change the plate thickness by clicking on the gear icon.
    Peter Van Der Walt and Rhett E like this.
  3. Rhett E
    Rhett E Well-Known
    Thanks Shawn, this is exactly what I was looking for. Do you happen to know the default measurements for this probe? I'm curious if there was a discrepancy. I've been chasing my tail trying to get my machine calibrated as best as possible.
  4. sharmstr
    9mm. I have mine set to custom as well. Mine is slightly undersized.
    Rhett E likes this.
