Cam Problem
Discussion in 'CAM' started by Bobbolink, Apr 15, 2024.
  1. Bobbolink
    Bobbolink New
    I pull up my drawing into cam and select the operation for laser operation, for some unknown reason it is not compiling the drawing . The cam window is not showing the version nor following through. Just sits there???
  2. Giarc
    I am a little confused. What do you mean by "not compiling the drawing"? Are you saying that in OpenBuilds CAM, when you are creating the gcode by selecting a vector and telling the software that you want to cut with the laser that it is not allowing you to create a tool path?
    Or, are you working with a really large and complex file so it is taking a long time to open?
    All toolpath parameters entered correctly?
    Include a workspace export (Save Project OBC file from top toolbar) for review
  4. Bobbolink
    Bobbolink New
    Computer updates strike again! Everything was working great till I did the update. Programmer cannot leave well enough alone, now I have to go through things to see what is screwed up[.
    Can't help until you provide the Project file as requested
    Everything tests fine here, so you'll need to provide a Project Export
    So we can load it up, see what you have, where the error comes from and suggest a fix for you.
    Your description is even to vague too work from. Would love to help, but you aren't coming to the table providing the info we need
    CONTROL and CAM are seperate applications :) - updating one can't fix the other. Only CONTROL has "updates". That way of thinking is the equivalent of if the plumber worked on your pipes, and you develop new electrical problems.
  6. Bobbolink
    Bobbolink New
    Tried to find problem all day yesterday; off loader the new downloaded program reinstalled twice; still would not compile my drawing. This morning off loaded the new download again thought I could run under the old one but that did not work either so downloaded the new program again loaded my drawing and it compiled it with no problems?? It appears to running ok tried a couple more times doing ok.
