can add fuction auto level from chilipeppr/widget-autolevel in software ?
Discussion in 'Control Software' started by witawat, Oct 24, 2022.
  1. sharmstr
  2. witawat
    witawat New
    i try add function autolevel in github and make connect wifi, but i not sure is ok on auto level
    i can't use function printLog on some file
    need send text to serial console and map to gcode ?
    #3 witawat, Oct 25, 2022
    We've never had time to fix the broken merge at To be tested at some point, sounds like an awesome feature by petervanderwalt · Pull Request #110 · OpenBuilds/OpenBuilds-CONTROL, nor test the code from that pull request, so if you can work on it to make it a proper, mergable, and fully tested feature we'd of course be happy to merge it.
    One more thought - I am more partial to fully frontend solutions - the one from To be tested at some point, sounds like an awesome feature by petervanderwalt · Pull Request #110 · OpenBuilds/OpenBuilds-CONTROL makes use of the backend as well (To be tested at some point, sounds like an awesome feature by petervanderwalt · Pull Request #110 · OpenBuilds/OpenBuilds-CONTROL etc)
    Chilipeppr's full frontend JS approach is more typical of CONTROL, can even be deployed as a Macro if we have doubts on merging it in as a fully supported feature (Getting started with Javascript Macros in CONTROL / Library of Macros created by the community) - so if I had to pick, it might be the one that i'd rather try to work on. It also uses ThreeJS like we do, so a lot of it can be ported
    Do note: CONTROL is aimed at beginners - so foolproof and easy to understand is key
