Hello, i am really new to the Arduino and Openbuilds Thing. I want to upload a Firmware from a bought Tutorial but can not connect to my Arduino Uno REV3 [A000066]. I use Openbuild 1.0.370 like the Tutorial said an try to Upload a hex file with the firmware flashing tool. This was the Output : [11:35:04] [ usb ports ] Detected a change in available ports: [COM4] [11:35:27] [ usb ports ] Detected a change in available ports: [ No devices connected ] [11:35:31] [ usb ports ] Detected a change in available ports: [COM4] [11:35:58] [ Firmware Upgrade ] [Starting...] [11:35:58] [ Firmware Upgrade ] esptool.py v2.6 Serial port COM4 Connecting... [11:35:59] [ Firmware Upgrade ] . [11:35:59] [ Firmware Upgrade ] . [11:35:59] [ Firmware Upgrade ] . [11:35:59] [ Firmware Upgrade ] . [11:35:59] [ Firmware Upgrade ] . [11:36:01] [ Firmware Upgrade ] _ [11:36:02] [ Firmware Upgrade ] _ [11:36:02] [ Firmware Upgrade ] _ [11:36:02] [ Firmware Upgrade ] _ [11:36:02] [ Firmware Upgrade ] _ [11:36:02] [ Firmware Upgrade ] . [11:36:03] [ Firmware Upgrade ] . [11:36:03] [ Firmware Upgrade ] . [11:36:03] [ Firmware Upgrade ] . [11:36:03] [ Firmware Upgrade ] . ... and so on .... [11:36:23] [ Firmware Upgrade ] _ [11:36:23] [ Firmware Upgrade ] _ [11:36:23] [ Firmware Upgrade ] _ [11:36:23] [ Firmware Upgrade ] _ [11:36:23] [ Firmware Upgrade ] _ [11:36:24] [ Firmware Upgrade ] A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header : Make sure the device is in BOOTLOADER MODE. Your computer failed to put it into Bootloader mode automatically. You can enter bootloader mode by: Press and hold down MODE, then Press RESET while still holding MODE. Let go of RESET, then wait a second or two and let go of MODE. Best performed right after starting the Firmware Flashing operation. [11:36:24] [ Firmware Upgrade ] [exit:2] [11:36:24] [ Firmware Upgrade ] Firmware Update FAILED! Please review the logs above, or try again I restarted the Arduino, i restarted the Laptop, i reinstalled the Driver. By using Arduino IDE i can upload a sketch, so .. it tells me Upload complete. I can not find any "Mode" Butto, just the Reset button. I hope it is just a little dump issue what i am missing. Thanks a lot !
Our flashing tool does not support Arduinos. Its for modern 32bit controllers like our BlackBox Asssuming JD? Ask the seller you bought from for support and let him know he should bring his own software to the table to support his venture, seeing as he is making money off you folks. It's a bit scaly. We don't mind someone private using CONTROL and always happy to help out, but its a bit of a stretch to expect us to provide software and having his customers come here for tech support, while not being in any way affiliated with us. His machine doesn't even make use of our parts. Its just abusing CONTROL. He is running a commercial venture after all. Sorry but that is just not right. You can also do the right thing Refunds and cancelations - and not support this sort of behaviour To use control and have our assistance, at least consider a BlackBox Motion Control System X32 to become a customer and gain support, or even better go with our Plasmas LEAD CNC 1010 Plasma Add-On
