Can the X32 replace a X-Controller
Discussion in 'Controller Boards' started by Jayhawk714, Apr 14, 2023.
  1. Jayhawk714
    Can the X 32 replace the Inventables X-Controller? If so will I still be able to use Easel Pro, LightBurn, Vectric Desk Top and such to send files to a laser or router? I been having a lot of trouble with the X-Controller and I'm tired of it, need to find another way to get my jobs done.
    It certainly can, though compatibility with Easel is mostly limited to the Export to Gcode option:
    You can do that, then run the Gcode in CONTROL docs:software:openbuilds-control [OpenBuilds Documentation]
    Learn more about the software world outside the closed ecosystems: docs:software:overview [OpenBuilds Documentation]
    Vectric is a definate yes! docs:software:vectric [OpenBuilds Documentation]
    As is Lightburn: docs:software:lightburn [OpenBuilds Documentation]
    Learn more about the X32: docs:blackbox-x32:start [OpenBuilds Documentation]
  3. Jayhawk714
    Super! Thanks for the links. I will go through them tonight.:)
