Cant get the Automatic sequence to work with XYZ PLUS
Discussion in 'General Talk' started by Steven Reckner, Feb 2, 2023.
  1. Steven Reckner
    I'm admittedly newer but not a total newb. I set this machine up perfectly when i get to the probing sequence it will not run am i missing something in grble i have no ideas totally frustrated to not be able to start using my new machine
    Tested myself against CONTROL V1.0.344 and a BlackBox X32 running the latest firmware (docs:blackbox-x32:firmware [OpenBuilds Documentation]) and it works perfectly here
    1) Make sure your firmware is up to date
    2) If it still has issues, post a Serial Terminal log of the attempt
  3. Steven Reckner
    Thanks Peter how long does it take to get logged ticket issues resolved?
  4. Steven Reckner
    Also i just downloaded it a few days ago i would think that would be up to date
    You downloaded CONTROL, but did you go through the steps in the documentation to update the Firmware on the BlackBox too?
    Within 24h usually, check your Spam folder too
