CarveCo Help
Discussion in 'CAD' started by jltcet, Oct 23, 2024.
Tags:
  1. jltcet
    jltcet Well-Known
    So I'm working with a 90 free trial of Carve Co. Been working it testing it out. Seams to work pretty good for my use other than every time I try and carve out a box. It always (NEVER FAILS) at some point it does not follow the vector and gets off track. Could any of the CarveCo guys take a look art my pic and tell me what I'm doing wrong. I like Fusion 360 but it's just to complicated for me.
    you might want to direct that question at Carveco support, but before you do, with CAMs its very often a problem of garbage-in-garbage out - i.e. How clean is your vector file?
    Can post it, i'll take a look, but basically most CAMs work better with nice clean polylines, properly closed vectors, no duplicate lines overlapping, points all in order (no reversed line segments going the wrong way) that sort of things.
  3. jltcet
    jltcet Well-Known
    I've contacted CarvCo also Thank you but your response gives me a Idea.Let ay know. Thank you
  4. jltcet
    jltcet Well-Known
    Ok Instead of using there Square Vector option I used the line vector option and made a box inside the box it came out perfectly. Your idea help me think of that. Thanks
