Change homing cycle for a two-axis machine.
Discussion in 'Control Software' started by Tourniquet63, Jan 9, 2025.
  1. Tourniquet63
    I am helping some students convert a shereline lathe to run on the black box.
    We've just got everything hooked up and are starting to calibrate, but I believe the default homing cycle for grbl makes this machine home z and then it homes x holding the x-axis with the limit switch to pressed until it homes y.
    Well we don't have a y-axis so we're just getting stuck on this x-axis home and waiting for y
    Is there a way to change The grbl firmware settings to home and then only home x?
    #1 Tourniquet63, Jan 9, 2025
    Set $44=4 (Does Z first up and out of the way before anything else, just good practice in case endmill was down in/on the job - get it up and out of the way before moving another axis) then $45=1 (Does X only, default is =3 which is XY)
    Its a bitmask:
    X=1, Y=2, Z=4 - so default of $45=3: [3=2+1] = X+Y at the same time
    Tourniquet63 likes this.
  3. Tourniquet63
    Works like a charm.
    Thanks Peter I couldn't quite find that info anywhere on the grbl wiki.
