chinese laser on 1500 with black box, only working at 25%
Discussion in 'Laser Cutters' started by Davecncheadache, Oct 10, 2020.
  1. Davecncheadache
    chinese laser, black box, initially i was able to use the laser, but now when i switch on it wont burn a fly. but if i turn on the spindle at a % i can get it to burn.
    Im confused as it was working. is there a grbl setting ive missed. Seems if the laser turned on via the spindle controlit works. but not as a laser.
    wiring is corect and working .
    Dave
    Look at $30 and compare that to the S values in your gcode
    For example M3 S255 but $30=1000 will be about 25%
    If $30=1000, you want S1000 to get 100%
    Or other way round, if your 100% setting spits out S255, then set $32=255
    Have a read through the whole Grbl Wiki sometime it is gold!
  3. Davecncheadache
    Thanks Peter, ive got to try and digets that first! new to gcode.
    I still dont understand as it was working. Anyway I will investigate.
    I even reset my eprom, re installes control software etc. its the second time its happened, last time i just reinstalled everything and it worked. But not this time.
    Dave
  4. Davecncheadache
    hi peter, i changed my spindle speed down to 1000 in my grbl settings and now the laser is working ok.
    Dave
