Closed Loop motors on Blackbox Duet2Wifi ?
Discussion in 'Controller Boards' started by Ian_SA, Oct 23, 2020.
  1. Ian_SA
    Ian_SA New
    Hi All
    I am currently building a new machine and will use closed loop stepper motors with drivers. I still want to use the Blackbox controller but am unsure whether I can just wire the blackbox motor terminals to the inputs on the closed loop stepper driver?
    I also have a Duet2Wifi board (from ooznest / workbee) and can potentially use that although I prefer to use the Blackbox.
    I also intend to connect a VFD in future.
    This is the driver I will use.
    #1 Ian_SA, Oct 23, 2020
  2. Alex Chambers
    There are people here much better qualified than I am to answer your question about the blackbox, but I believe with the Duet2 you need to use external drivers. You can add up to 5 external drivers to the Duet using an expansion board.
    That's the limit of my knowledge on the subject, but the link below might be a starting point for more research.
    Closed loop duet.
