CNC 3018 pro with BlackBox motion control system
Discussion in 'Controller Boards' started by Thepreppy, Nov 10, 2021.
  1. Thepreppy
    Thepreppy New
    Hi everyone I'm new to this forum.
    Maybe it's crazy but I would like to improve my CNC 3018 pro which is fitted with a SainSmart Genmitsu GS-775 20,000 RPM spindle (https://www.sainsmart.com/collectio...s-775m-24v-20-000-rpm-motor-noise-suppression) with the BlackBox Motion Control System and a power supply (input: 110 V / 220 V 50/60 HZ. Output: DC 24V max 10A, 240W. Default output voltage 24 vdc): can it be done or are there incompatibilities?
    Knowing nothing about electronics, I kindly ask you for help.
    All this comes from having burned the control board of the CNC 3018 pro (https://www.sainsmart.com/collectio...r-genmtisu-cnc -router-3018-3018-pro-1810-rpo) when I connected the aforementioned 20k spindle although I took all precautions to avoid overloading the power supply through a gradual start-up of the spindle (as indicated in the file that I attach), when I brought the spindle to 100% perhaps because (somehow) it required more current than the controller board could handle (although in theory the control board had an Input voltage of 24V (12-24V)
    In short, I don't want to take the risk of burning another card again. I got bored!
    Waiting for a kind reply, thank you in advance
    You need a PWM Motor controller to run a DC motor. You cannot just connect a motor straight to a control signal, you need a seperate power supply, and a Motor controller as well
  3. Thepreppy
    Thepreppy New
    Thanks Peter, but can't I manage the modulation of the spindle start-up (and working) speed directly from the Candle software? Do I need to install a Spindle speed controller?
    #4 Peter Van Der Walt, Nov 10, 2021
