CNC cutter
Discussion in 'General Talk' started by bo Toepfer, Aug 7, 2020.
  1. bo Toepfer
    Hi I just built my first CNC a LEAD 1010, I cut the Hello World using a 1/4" end mill, It appears to be too big of a bit for the job. My question is what is the correct bit or can I enlarge the file to cut it bigger and use the bit I have. I found no data for this anywhere, Thanks
  2. Giarc
    I am not familiar with the file, but you could open it in a CAD program like Fusion 360 and measure the diameter of the smallest curve/corner to determine the bit size. If I had to guess though, I would bet it is for a 1/8" endmill.
    On the right under Toolpaths, you can Edit the toolpaths and set Endmill Diameter, then Generate Gcode again - the default is indeed a 1/8th and that is discussed in the Hello World video tutorial
    But you can always view/edit CAM parameters:
    Each toolpath has an edit button:
    And inside the parameters, you can view , or change any of the parameters to your hearts desire
    Apply, updates the preview
    Then click Generate Gcode
    #3 Peter Van Der Walt, Aug 7, 2020
