CNC Pocket Path
Discussion in 'CAM' started by CNC.Tom, Jun 12, 2023.
  1. CNC.Tom
    CNC.Tom New
    Hi guys,
    Thank you for your amazing work on Openbuilds softwares.
    I wonder why, while generating G-Code, Cam sets the spindle to move from an area to another at each path in Pocket mode instead of doing each path of an area.
    That would reduce a lot the spindle move across the entire area, even more for multiple passes.
    I guess there is a good reason for that ?
    Tom
    That's up to the operator. If you select both paths and add them to a toolpath together, and apply a pocket to both at the same time, its treated as a single piece of geometry.
    But if you create each as its own toolpath, it finishes each one on its own too. Full control to the operator
  3. CNC.Tom
    CNC.Tom New
    Oh !
    Thanks so much, it seems logical.
    Adding an option to choose operation mode even when we apply a pocket to both paths at the same time should be useful.
    On a complex piece it should take a lot of time to optimize execution setting each path individually.
    Edit : This is all the more interesting since we could thus modify the parameters of all the paths at once.
