CNC Router Vector Design Help Needed
Discussion in 'CNC Mills/Routers' started by Jake Borg, Sep 20, 2020.
  1. Jake Borg
    Jake Borg New
    Hi guys, I am waiting for my workbee to arrive to start the build. I purchased this to mainly cut acrylic for a specific type of sign I want to make. I need some help on a design issue Im trying to figure out. Basically I would like to Write a text in a monoline font, set an offset of around an inch cut the outside of the offset and engrave a pocket in the text monoline font.
    The issue I am having is that I would like to engrave a 10mm width with a depth of 2mm inside the text, however enlarging the text to fit the size I would like to cut it out will not be 10mm in width. What is the best and easiest way to achieve a mm engraving inside the text ?
    I have attached an image example where the white part is where I would like the 10mm pocket engrave to be and black part would be cut from the outline.
