CNC xPRO Driver
Discussion in 'Other Builds' started by Spark Concepts, May 25, 2014.
  1. snokid
    snokid Journeyman
    yes, if I don't do it by Tuesday, remind me.... Going up north for the weekend!!!!
    Have a great weekend everyone!!!
    Bob
  2. GrayUK
  3. snokid
    snokid Journeyman
  4. Darus
    Darus New
    I take it you havent wired up the homing switches or the start/hold/reset ones ether? I build my ox about a year ago, but just started to have the time to play with it. I was getting a faulty prob when trying to use the touch plate.
  5. snokid
    snokid Journeyman
    No, for me the way I use it I really don't need limit or homing switches....
    what fault are you getting with the touch plate?
  6. Darus
    Darus New
    I got it working with shorter wires, but I still find it a little flakey. Using the 5+ and ground. I just need to wire up the limit switch just as a safety if it goes wonky.
  7. dirtdemon
    dirtdemon New
    Hey guys just getting my of kit up and running. Bought the kit from smw3d but went with a cnc xpro instead of their tiny g. I'm working on getting all the settings nailed down and have run into a couple issues with the x and y. First off they both seem to be a bit noisey and can almost make out the steps in the noise, the z is nice and smooth tho. Also on the same two axis my movements are consistently off. The same on both x and y one step is 1.012 next step is 0.975 then 1.013 then it repeats In that order if I continue jogging. Any suggestions? Oh I am using 26.667 step/mm for both x and y
  8. Darus
    Darus New
    What g code sender are you using, I found by using the universal gcode sender resovled my issue with noise steps.
  9. dirtdemon
    dirtdemon New
    Have tried ugs grbl panel and grbl controller all the same findings
  10. GrayUK
    Noisy motors are synonymous to having a low power supply, usually in the Amps department. :rolleyes:
  11. dirtdemon
    dirtdemon New
    Using the 24v 350watt psu supplied in the kit running 3 Nema 23 and one Nema 17 steppers
  12. Ronald van Arkel
    Or the other way around; not enough juice. Still, in both cases the variable resistor needs to be adjusted @dirtdemon, and I also know what your first upgrade will be: swapping out the NEMA17 for a NEMA23 ;), sure, the NEMA17 is okay for testing and soft materials (foam and the like).
    -Ronald
  13. dirtdemon
    dirtdemon New
    Tried adjusting the pots but didn't seem to change anything even turned all the way down it still moves and sound the same at 0 or 100 percent or anywhere in between. As far as the Nema 17 goes from wat i read on smw3d site the 23 is a bit overkill but we will find out if I can get the rest sorted out. The psu has also been check as it putting out exactly 24.0 v
  14. Ronald van Arkel
    Hmmm, try 1/8 divider for the NEMA23 motors, it should work smoother and might solve your problem. Also, use a fan on the xPRO to make sure it0s not terminal throttling. And the Z-axis; NEMA17 might suite your needs, but most problems come from not having enough holding torque and thus uneven cutting depht.
    -Ronald
  15. dirtdemon
    dirtdemon New
    @Ronald van Arkel they are already set at 1/8 step, all three axis. And also using a 30x30 fan blowing directly over the board mounted in a box.
  16. Ronald van Arkel
    My bad, 1/16, just to test as 1/8 should be good. You are using 3GT /GT3 belt right? Any specs on the motors or are they the 175oz ones?
    -Ronald
  17. dirtdemon
    dirtdemon New
    Just tried 1/16 steps seems to be the same way. Yes I am using gt3 belts and Pulleys. The Nema 23 steppers are 175 Oz. Wat if I go the other way with the steps... To 1/4 will that make it better or worse?
  18. dirtdemon
    dirtdemon New
    Well I got the inconsistent movements squared away. Just fiddled with settings ended up bumping the steps/mm up to 27.000 for x and y and now they r spot on... Now just the noise issue remains. I did manage to get it a little better by changing some of the settings but oddly the noise from the steppers has a different tone depending on which program I try to jog it in... Have been using ugcs and grbl panel mostly.... Seems to be louder or more pronounced growling in grbl panel. I could just use ugcs but the way I have my spindle setup is using the software to adjust speed thru pwm and I don't see anywhere in ugcs that supports thst so would rather stick with grbl panel. Any more suggestions?
  19. Darus
    Darus New
    Here are the settings I use.
  20. dirtdemon
    dirtdemon New
    Here's where I'm at currently. Doesnt make sense why they sound different between the two programs when the grbl settings r the same. 0607162222a.jpg
  21. dirtdemon
    dirtdemon New
    Also is there something In the programming that I need to enable to use the spindle speed pwm outputs? Tried running a simple program today just cutting air, went pretty well except when I hit start the spindle started to spool up then shut off and don't come back on for the rest of the program
  22. bnbellis3377
    Need help!!!!
    I finished my cbeam. Downloaded the software for the xpro through openbuilds,plugged the xpro in and everything seem right settings there went through the setting according to the JPEG . Hooked up the power supply 24v 350w 15 amps, jogged motors everything was good. When I tried again the next day I had yellow LEDs on the board for the coolant and spindle and there were no setting on the settings tab, through different emails (spark concepts and openbuilds) they said the drivers may need to be updated, tried that but still no setting. Any help Also was reading on github grbl setting ,that the grbl could be restored if so "how" I have no command line to work with
    Thanks for the help Brian
  23. Steve Fox
    Steve Fox Well-Known
    Hook the Uno up to your PC and boot the Arduino IDE.
    Set the correct COM port.
    Go into TOOLS>Serial Monitor.
    Type in $RST=$
    That should do it.
  24. bnbellis3377
    Thank you for the reply I'll try that tonight when I get home
  25. bnbellis3377
    Update to what mr fox said to try, that didn't help, thank you though I was reading on forums that it could possibly be bricked if so would that cause my problems and can it be fixed or should it be trashed thanks again brian
  26. Spark Concepts
    Spark Concepts Journeyman
    If the arduino ide didn't help, the microcontroller is likely bricked. Luckily, it is a pretty straight forward repair. If you send an email to [email protected] I can walk you through the repair, or you can send it in and ill get it repaired for you.
  27. bnbellis3377
    Thank u
    I'll send an email tomorrow it would probably be better if I shipped there I don't have access to the computer till late evening. Reading forums and email is all done through my phone
    Thanks again Brian
  28. James Ellis
    Can a touch plate be used with the CNC xPro? if so how and where do I connect it?
    I am just about to wrap up my ooznest OX 1000x15000, CNC xPro, limit switches, DW611 using a Raspberry PI 3 running Raspian Jesse and ZapMaker Grbl Controller.
  29. Julius
    Julius Well-Known
    Its said not to use Grbl controller.
  30. James Ellis
    Do you know why that is or where it says that? This is the custom build I am using with a few slight modifications. Thanks for the heads up as well.
