CNC-xpro-v2-controller stopped working
Discussion in 'CNC Mills/Routers' started by TheWeps, Sep 9, 2024.
  1. TheWeps
    TheWeps New
    I have a cnc-xpro-v2-controller. It was working fine for years, but not it stopped working.
    When I give a command to move an axis then the stepper is released (I head a click). But it is not moving. When the controler thinks the axis is at the destination it locks the steppermotor again.(Click)
    When the axis should be moving, I can turn the spindle of the stepper motor by hand, until it reached the destination (not really, but the controller is thinking that) and its locked again.
    I happens on all 4 steppermotors.
    I use bCNC on Windows.
    This is what the log says:
    Controller state changed to: Jog (Running: False)
    Controller state changed to: Idle (Running: False)
    Nothing happens when I give the Homing-command ($H)
    Is it possible to flash the software again?
    Rob
    Incorrect Grbl Settings, mostly $4 set incorrectly. But likely others too (if it forgot one, it forgot them all - causes for EEPROM corruption could be wiring short, user error, accidental reset of settings, wrong machine profile etc)
    Restore your last good Grbl Settings backup
  3. TheWeps
    TheWeps New
    Thanks, that was easy :)
