CNC4Newbie Controller swap
Discussion in 'CNC Mills/Routers' started by Dion M, Apr 13, 2025.
  1. Dion M
    Dion M New
    Hello I am new here, but wanting to add a Laser to my table. I have a Cnc4nnewbie 4848 with VFD 2.2kw air spindle running off Uccnc to the Gecko G540. The 4 axis all have Nema 23 269oz. stepper motors.
    I have purchased an OPT laser with Lightburn and would like to use Vcarve laser module. I am starting to think holding on to Uccnc is not going to happen since lasers do not want to play well with it.
    I have looking at the CNC Electronic Bundle in the shop, should I replace mine with the high torque oe will I be fine?
    is this all I would need to get running again?
    To determine if you can reuse your existing motors, check your motors' electrical specs:
    BlackBox will work best with motors that have 3-6v coil voltage (higher = slower acceleration), 1-4mH inductance (any higher and they will be slower on top speeds) and 1.7-3.2A Current (rated much higher will be low on torque).
    We would also usually recommend fitting our recommended PSU Electronics & Software - Power Supplies - OpenBuilds (BlackBox likes good, clean reliable 24v power) and our limit switches, they are filtered - which helps a lot with potential EMI issues: docs:blackbox-x32:connect-xtension-limit [OpenBuilds Documentation] - note they need a 3-conductor cable so if your existing switches uses 2-wires for example, you'd also need some 3-conductor cable to replace it with: Xtension Wire By the Foot
    Checkout docs:blackbox-x32:start [OpenBuilds Documentation] ahead of time, see what you have and hows it wired up, and what else you may need.
    As for laser jobs, checkout https://us.openbuilds.com/lightburn/ too - usually a better option than Vectric. See docs:software:overview [OpenBuilds Documentation] as well
  3. Dion M
    Dion M New
    I just ordered the CNC Electronics Bundle with new high torque motors and the interface CNC touch. I have been trying to figure out how to and where to mount as the old controller is in back under the table will I need to touch the black box once everything is hooked up?
  5. Dion M
    Dion M New
    I wired the power supply under front of the table, the black box I mounted on the top so I could see the LEDs with a cover to keep the dust off. I got some shielded cable as I already have had EMI when I first setup the table with the old controls and bad usb cable.
