Connecting with PySerial requires a reset
Discussion in 'Other Software' started by flashmasterdice, Feb 24, 2025.
  1. flashmasterdice
    Hi! Thanks for reading.
    I'm controlling the BlackBox via Python and PySerial on Raspberry Pi (Raspberry Pi OS). It works great. One problem I have and can't figure out is why I have to press the Reset button to get the script to work a second time. I have used this code on another controller board and I don't have this problem. When I connect to the Black Box via CuteCom or Arduino IDE Serial monitor, i don't have the problem. I feel like these programs are doing something to properly close the connection I'm not. Below is a sample script I've been using for testing purposes.
    If I use one of these terminal emulators to open and close the serial connection, then I am able to reconnect via PySerial.
    Thanks for any help.
    Code:
    import serial
    import time
    dev = serial.Serial('/dev/ttyUSB0', 115200, timeout=2)
    time.sleep(2)
    while(True):
        response = dev.readline().decode('utf-8').strip()
        print(response)
        uin = input("> ")
        if(uin == "quit"):
            dev.close()
            exit()
        uinb =  bytes(uin, 'utf-8')
        dev.write(uinb)
        time.sleep(1)
