Connecting with Wifi ... almost there
Discussion in 'Control Software' started by deonholt, Nov 11, 2023.
  1. deonholt
    deonholt New
    Hi again.
    Thanks Peter for your help with my 1st question.
    1. I get my MKS board to connect to the Wifi.
    2. I open Openbuilds with the USB cable connected.
    3. I connect with the USB cable.
    4. In the startup log, Openbuilds sees/acknowledges my Wifi and sees the SSID and the status is connected.
    5. When I tell OB to scan network, it says that there is nothing and that it misses a port.
    6. the documentation on the BlackBox states: "Scroll down to $73 Wifi Network SSID and $74 Wifi Network PSK"
    7. When I do it, there is no $73 or $74
    I know I am very close but cannot figure out the last piece of the puzzle.
    Can someone please advise? Maybe I am doing everything wrong or in the wrong order.
    Thank you very much.
    1) use a grblhal based controller
    2) make sure telnet is enabled
    3) telnet available on default port
    trying to use a 3rd party controller is "at own risk"
    If you want a working solution with support (both as in supported by the software, but also as in access to Tech Support) consider a BlackBox from Openbuildspartstore.com
    #2 Peter Van Der Walt, Nov 11, 2023
