controller
Discussion in 'CNC Mills/Routers' started by AmirSigns, Dec 11, 2024.
  1. AmirSigns
    AmirSigns New
    Hi, I need your advice . what the best controller if I want to replace the controller for a large CNC router (12' x 6') with 3-phase power.
  3. AmirSigns
    AmirSigns New
    Can this controller connect to a spindle control VFD 3-phase inverter?
  4. AmirSigns
    AmirSigns New
    The existing CNC does not have limit switches. When homing, as soon as the X or Y axis touches the end, the stepper motor acts as a switch. Can I use this setup, or do I need to add limit switches
  5. David the swarfer
    that will depend on the the present stepper motors.
    What voltage are they running at?
    What current are the present drivers supplying?
    The Black box can do 24 volts at 4 amps, max.
    This means that if the machine has stepper motors that are running at say , 48 volts and 6 amps, then you need a controller that can interface with those drivers, which a Blackbox cannot do.
    Then you need to look at products like UCCNC, Masso, Mach4.
    AmirSigns likes this.
  7. AmirSigns
    AmirSigns New
    the motor is Pittman 24v. (1000 CPR) control with Advanced Plotting Devices(APD)
  8. likorplf
    likorplf New
    For a large, 3-phase CNC router, if you are looking for industrial-grade reliability, Siemens Sinumerik, Heidenhain, and Syntec are excellent choices, though they come at a higher cost.
