Converting An Old CNC Router
Discussion in 'CNC Mills/Routers' started by rbrpguy, Jun 22, 2023.
  1. rbrpguy
    rbrpguy New
    Hi, I am new here. I have an old CNC Mogul. It utilized a UC100 Motion Controller that seems to have failed, that and/or the board after many years of service. Can I easily swap out the old technology with the new Black Box MCS X32 and 24-volt power supply bundle? I would like to mount them in the same location. My power supply is 9" x 4.5" overall and motion 7.5" x 6"overall. Thanks! motion.jpg power.jpg
    Try to post datasheet (or model no, but then we have to google up a datasheet (; so easier if you do find a datasheet) so we can check if their electrical specs are suitable (Resistance, Inductance, Coil Voltage, Current)
  3. rbrpguy
    rbrpguy New
    Found this. Hard to find info. The machine is 13 years old.
    The controller is a Chinese Tb6560 Stepper Motor Driver Controller that is controlled via parallel port.
    The power supply is a 24V 14.6 AMP 350W Max Power Supply.
  4. rbrpguy
    rbrpguy New
    Stepper Motor Controller Specs:
    If it ran well on TB6560s it will run great on a BlackBox. It uses TB67S109s (newer chip but same manufacturer as the TB6560s = Toshiba)
    I would recommend replacing the PSU with ours (just to protect your warranty - 3rd party PSUs can damage BlackBox and void warranty) and also our Limit switches (Onboard EMI filters)
    Checkout docs:blackbox-x32:start [OpenBuilds Documentation]
    For 3rd party motors you'll need to ID the coils: docs:blackbox-x32:faq-identify-motor-coils [OpenBuilds Documentation]
    Xtension Limits: docs:xtensions:limits [OpenBuilds Documentation]
    Recommended PSU bundle (with safety cover called a PowerCase): docs:powercase-v1.9:start [OpenBuilds Documentation]
    Modern software toolchain: docs:software:overview [OpenBuilds Documentation]
    Optional Probe docs:xyzprobe:start [OpenBuilds Documentation]
  6. rbrpguy
    rbrpguy New
    Thanks so much Peter! I will follow all your recommendations!
