Cube 3 / Pro hacks
Discussion in '3D printers' started by eychei, Jan 16, 2017.
  1. gabriell28
    i´m sorry buit i still dont get how it works.
    I download the cubetool box, but how do i get the firmware to patch it ?
  2. Tom Dirriwachter
    Tom Dirriwachter Well-Known
    I would suggest being very careful with the CubePro. Several complaints have been lodged saying the chamber heater fails after the patch. Considering you have to interrupt the installation process, this is a problem that only shows up for some. I've settled for the chip recharging solutions for CubePro. This is not the case for Cube3. The installation is cleaner.
  3. DPcroghan
    DPcroghan New
    Hello, I have a CubePro that I purchased in 2015. It has worked fine for all this time. However, my last print failed miserably and since then the printer’s jet carrier will get to a location near the left rear and seize and buzz/squeal until the power is turned off. It is easy to reproduce by simply pressing the Change Cartridge on the main menu. The carrier will move to the same point and just buzz…. However, I can manually move the jets all around without any issue. I can test the jet and the filament flows just fine.
    Does anyone have any idea what the problem is and how I would go about fixing it. Sorry if this post is hijacking the thread? Point me to another forum and I will happily post my question there. Thank you for any assistance!!!!
  4. Digital Creativity
  5. JT3D
    JT3D New
    Digital Creativity likes this.
  6. Digital Creativity
    Thank you JT3D for that quick reply, it helps a lot, placing the order now and will get back as soon as it arrives!
  7. Digital Creativity
    For anyone that comes across this posting, the following power supply for the Cube 3rd generation works well, attached are the pictures.
    #637 Digital Creativity, Dec 8, 2024
  8. Digital Creativity
    Can anyone recommend a current PLA filament that works well with the Cube3?
    Thanks!
  9. JT3D
    JT3D New
    FWIW (it's been a year since I printed anything...)
    I've used PLA by
    MatterHackers / MH Build and
    MakerTree3D
    Both print fine, but you may have to modify the print temperature to optimize. There is a program by written by BuddyBu to manipulate the .cube3 print file; it may be mentioned somewhere in this thread. I suspect most any decent PLA will print ok. Different colors sometimes do better or worse.
    I've also used PETG; I like it a bit better than PLA. It seems a bit stronger/stiffer and a little more temperature resistant. One way to do that is to exchange the Cube's firmware to make it into an EcoCycle Cube and modifying the cartridge to change it into an EcoCycle cartridge. But this is a whole 'nother rabbit hole!
    Alternatively, you can slice it as PLA then modify the .cube3 file to adjust temperatures to suit PETG on the regular Cube 3.
    Long answer... probably more than you wanted to know!
  10. Digital Creativity
    I really appreciate all your help and info, knowledge is power, but impossible to know it all.
    From my short experience, setting up the printer has been very easy. All the software works perfectly even in Windows 11.
    The impossible and worse of it all are the filament cartridge. All the time I have spent is getting the filament to make it to the printer's head.
    It breaks easily, even by having the reel outside.
    Thank you for the info!
  11. JT3D
    JT3D New
    The problem is the 3DS media is so old now it has become brittle, partially because of moisture absorption. I think it might be possible to recover it somewhat by drying it out in an oven at low temperature (below it's melting point! Maybe 150F or so?)
    Have you found info about modifying the cartridges for feeding bulk filament, and replacing the bowden tubes, etc? There was another website www.print3dforum.com that had a wealth of Cube 3 info, but it seems to be offline now. Tom Diriwachter, who is on this thread, was the webmaster.
    I have some of the info and can share if you're interested.
  12. Digital Creativity
    I have been doing my search before asking as this is all new to me, but it is very unfortunate that the (( print3dforum )) is no longer available. There was a lot of valuable information there that is harder to find now. For example, the nozzle drill jig, file name: Drill_Fixture_15deg.zip.
    Screenshot of the original posting, from wayback machine.
    youtube video, cartridge mod:
    Ebay link, to buy it:
    Cube 3rd Generation 3D Systems Printer Open Source Conversion Cartridge Silk PLA | eBay
  13. JT3D
    JT3D New
  14. Digital Creativity
    I wish I knew more, I am doing baby steps with this new toy.
    The attached pictures show my own inspiration MOD for the Cube3. With this set up I can use all the 6 cartridge even if the filaments are not in optimal condition.
    I open the nozzle and decided to do it my way, it is extremely basic. One hole going to the top and keep all the original tubing and connections.
    The mod requires, one hole in the nozzle and a bigger hole on the front cover of the cartridge.
    Total cost $ 0.00 (no extra parts need it, all stock)
    For the filament reel, I used PVC, cost $8 each.
    All works perfectly, perfect!
  15. Mark Fullerton
    Hi, just been given a cubepro duo. Dont have any original spools. So this firmware hack wont work is that right? Do you need an original spool that is more than 0 and less than 100 % ? Did I read that right?
    I also downloaded the cube toolbox and the firmware, but it comes up with error patching firmware when I try and patch it.
    Any advice on where to go from here greatly appreciated.
    I have a wanhoo Di3 printer with heaps of different PLA filament.
  16. Tom Dirriwachter
    The problem with 1/2 of the cartridges out there is that the OG Bowden tube was overly aggressive with the over-mold of the caterpillar tracks shrinking the ID enough to capture the filament once it got a little warm. The tell-tale failure mode is a lot of retractions doing infill.
    I do have a solution for you, though. 3D Systems Cube 3 Adapted Nozzle by Qube3Bot is a simple fix for the nozzle; and a cartridge adapter https://www.thingiverse.com/thing:3889974.
    There are more in my collection if you dig around.
  17. Tom Dirriwachter
    You might think twice about the CubePro hack. There have been a number of reports that it fried the chamber heaters. Something about interrupting the install that messes things up in some cases. Cube3 doesn't require this exchange. I highly recommend a chip programmer for CubePro.
  18. Mark Fullerton
    Thanks for the info. When you say a "Chip programmer" do you mean an actual person that can hack into it and re program the chip? (Thats what I found people have done in a search) or has someone come up with a hack device that can re program the chip?
    Also came across someone that has up graded the controller to a Duet2 wifi. That actually seems like a fairly decent solution. Seems to solve a lot of problems with the cube.
  19. Tom Dirriwachter
  20. Mark Fullerton
    I have seen that but I think it requires having an original spool? I got given the printer with no spools so would have to try and find an old spool. I could ask the school that was chucking it out if that had any old ones.
  21. Tom Dirriwachter
    Ah, yes. Nothing gets away from needing a chip.
  22. 3Dprinting is the gout
    is it worth it buying a cubepro trio on ebey for $400-$500?
  23. Tom Dirriwachter
    CubePro is a closed system with little option. It is also a bit top heavy making it a loud machine. I own a duo and several Cube3's. I have less than a day on the CubePro where I've worn out Cube3's.
    You will also need a cartridge resetting tool. The FW hack is unreliable. If the hack had been installed, make sure the chamber heater is still working before you buy. The hack has disabled the chamber heater on several users' machines.
    People have done well with yarding all the electronics and making it a open source printer with new controllers and hot ends.
  24. 3Dprinting is the gout
    how much did you pay for yours i want to know what is a good pries for one
  25. 3Dprinting is the gout
    and also if you did do the FW hack cant you reinstall the original firmware?
  26. Tom Dirriwachter
    I think I paid $500 to my door.
    As to swapping back to valid FW, it is hard to say as no one has found the failure mode other than a chamber heater error message that is not fixed by swapping back.
  27. 3Dprinting is the gout
    I assume you pad about $100 for shipping
  28. Tom Dirriwachter
    It required freight. It was included but at the time, what, 5 years ago (?) it was $199 to freight. My Duo was brand new. Someone was clearing out a large lot of these things. They ship on a pallet.
  29. 3Dprinting is the gout
    if i do want to do the hack where can i find the firmware to put in to the toolbox for it to patch because i don't want to buy one and not know what to do with it
  30. Tom Dirriwachter
    Page one of this thread is the hack. The problem may be obvious when I tell you that you have to start the upgrade with the current valid firmware and then pull the USB drive during the install and replace it with the hacked FW. This interrupt is highly suspicious as the Cube3 doesn't require this swap. It works flawlessly for Cube3 although it requires cartridge chips to be in a 'used' state' (initialized).
    The chip reset algo is more reliable. I used the haxtom.com solution and it worked a treat. The minimal build is a NANO and a 2.2K resistor.
