Cutting in a circle.
Discussion in 'CNC Mills/Routers' started by MAFFPL, Mar 23, 2022.
  1. MAFFPL
    MAFFPL New
    Hi.
    Probably a simple topic for you, but I can't deal with it. How can I set a Lead 1515 with a Dewalt 26600 spindle to have the machine mill in a circle, gradually (spirally) going down to the workpiece like in this video?
    https://www.youtube.com/shorts/Hpj3L_THI_g?&ab_channel=V-slotPolska
    Works on cam.openbuilds but maybe there is some other program?
    Thank you.
    Almost all CAMs has a function for this, typically called "Ramping"
  3. MAFFPL
    MAFFPL New
    There is this feature in cam.openbuilds.com, but unfortunately it doesn't work.
    yes as mentioned, some CAMs do. OpenBuildsCAM is a beginner CAM, it doesn't do helical ramping only straight line ramping
  5. MAFFPL
    MAFFPL New
    What CAM would you recommend?
    See the Software section of docs.openbuilds.com for more suggestions
