Default network for the jog widget
Discussion in 'OpenBuilds Bug Report' started by dawhite, Mar 11, 2023.
  1. dawhite
    dawhite New
    Hi, just an observation more than a bug, but I'll let you be the judge!
    The jog widget grabs the ip from the first network it sees... Probably not a poor assumption, but it's not the correct network. I'm able to work around it, of course, but it would be nice if it there was a flag (if present) in the config somewhere that would let me choose the adapter the widget picks, ergo setting the qrcode for the correct or desired network.
    Oh and while I'm here,
    is there a minimum device required? I was hoping to repurpose an ipad 2 (ahem) as an interface...
    here's an example windows ipconfig from my VMWare host:
    Ethernet adapter Ethernet:
    Connection-specific DNS Suffix . :
    Link-local IPv6 Address . . . . . : fe80::e5ed:a4ee:2357:95cb%8
    IPv4 Address. . . . . . . . . . . : 192.168.1.19
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 192.168.1.1
    Wireless LAN adapter Local Area Connection* 1:
    Media State . . . . . . . . . . . : Media disconnected
    Wireless LAN adapter Local Area Connection* 2:
    Ethernet adapter VMware Network Adapter VMnet1:
    Link-local IPv6 Address . . . . . : fe80::a3ef:45dd:f0b0:8518%19
    IPv4 Address. . . . . . . . . . . : 192.168.38.1
    Ethernet adapter VMware Network Adapter VMnet8:
    Link-local IPv6 Address . . . . . : fe80::e220:153d:2437:2fed%17
    IPv4 Address. . . . . . . . . . . : 192.168.222.1
    Wireless LAN adapter WiFi:
    Ethernet adapter Bluetooth Network Connection:
