Deflection during surfacing jobs
Discussion in 'General Talk' started by BASt_NL, Jul 21, 2023.
  1. BASt_NL
    BASt_NL New
    I'm experiencing an issue with the flattening wizzard... or rather with the tool.
    When the tool passes from right to left, there is zero 'bump' , when it passes from left to right, theres a tiny little bump.
    Since it is only in one direction it seems to be caused by the difference in tool deflection in climb and conventional cut rather than a tramming issue
    Am i correct or missing something?
    If so; would it be feasible for me to do the flattening with only climb cuts?
    It should be able to do both, so something else needs fixing:
    Hold the endmill and give it a wiggle - if you feel any play - follow the play by hand (easier to detect unwanted movement through the sense of touch - much more sensitive sense) to find the source. Could be wheels needing adjustment, etc
  3. David the swarfer
    and check the tram too
