Difficulty calibrating workbee
Discussion in 'CNC Mills/Routers' started by Brandon Hurst, Feb 1, 2020.
  1. Brandon Hurst
    I seem to be a little out of my league. After numerous problems getting everything square, then figuring out why it wouldn't complete a surfacing job, I got both those fixed and set. Made sure all my eccentrics were set. Made sure the backlash was set properly. I pre calibrated with the ob control wizard and then followed ooznest's video on calibrating the steps per mm. Done. Run the same calibration test and now it's not close. So I rerun the calculation and try to confirm again and it's off. I'm not sure where to go from here. A 60mm square will come out between 58.9 - 60.5mm. There doesn't seem to be an axis within the .2 I should be seeing. Pockets are cut .5 - .9mm undersized or oversized.
  2. cmitcham
    cmitcham New
    is everything tight? if your dimensional problems are calibration only, then every 60.000mm square would be the same identical size, whatever that size is.
