Do you have the High Z mod? I have a quick question...
Discussion in 'CNC Mills/Routers' started by Trent Paulk, Feb 20, 2023.
  1. Trent Paulk
    Hello,
    Can anyone tell me what the actual measured clearance is from a 1/2" spoil board to the bottom of the c-beam end cap is after installing the High Z mod? Thank you!
  2. Albert64
    Albert64 Well-Known
    Good morning, if you are referring to the vertical z axis c-beam - that is adjustable depending on the height of the material to be cut/engraved. Other factors include the length of the cutting tool. I keep mine set up to account for clearance of any hold down clamps. Hope this addresses your question.
    #2 Albert64, Feb 21, 2023
    Rick 2.0 likes this.
  3. Trent Paulk
    Sort of...
    If the z axis c-beam is adjustable, then what is the maximum measured clearance from a 1/2" spoil board to the bottom of the c-beam end cap. To rephrase in a shortened form...what's the tallest piece you can fit on the router?
    According to docs:machines:comparison [OpenBuilds Documentation] about 200mm - but if in doubt grab the CAD model from the Build page to properly explore and play with it - you can use Sketchup free to move it around and slide the carriages around etc - then use the built in measuring tools
  5. Albert64
    Albert64 Well-Known
    Approximately 8 inches of clearance - I am using a 3/4 inch spoil board. Another advantage of the high z modification - I was able to increase my x axis work area to 49 inches; which gave me the ability to safely cut/engrave work pieces at 48 inches wide. I have attached an image for visual reference.
  6. Trent Paulk
    Nice! Thank you.
  7. Trent Paulk
    Thank you!
