Does PostGrbl.cps need a special group in Fusion 360?
Discussion in 'CAM' started by Webweave, Jun 24, 2022.
  1. Webweave
    Webweave New
    Every time I make a setup using "OpenbuildsFusion360PostGrbl.cps" I get a save error, "cannot be saved" "cross-team reference"
    thanks, -Brian
  2. sharmstr
    Are you sure you mean setup? Creating a new setup doesnt involve the post processor at all.
    What version of the post are you using? What version of fusion (paid or free)?
    A screenshot of when and where this error happens would be helpful.
  3. Webweave
    Webweave New
    In the MANUFACTURE tab. SETUP, Machine, OpenbuildsFusion360PostGrbl.cps 4/11/22
    Startup License
  4. David the swarfer
  5. Webweave
    Webweave New
    "Design contains external reference(s) from other teams."
    This video shows the problem.
  6. sharmstr
    I cant replicate that error.
    What happens if you dont select a machine in your setup and DONT check "Use machine configuration" in the Machine and Post post processor settings?
  7. Webweave
    Webweave New
    -I can save if I select nothing.
    -I can also save if I select the Generic Autodesk 3 Axis.
    -The problem seems to be the Openbuilds Workbee 1010 machine library, I was using an earlier version and updated to the April 2022 version same problem.
    -looks like I'm moving back to the Generic library.
  8. sharmstr
    Maybe startup license doesnt allow for it. I dont know.
  9. Webweave
    Webweave New
    I just looked, Autodesk says it's the same as the full version.
    Could be worse. Thanks.
    Did you install the post yourself, in your own cloud library - or was it installed by another member of your "team"
  11. Webweave
    Webweave New
    It was done by me.
  12. sharmstr
  13. Webweave
    Webweave New
  14. sharmstr
    Not the post processor. The machine profile you are using. Did you create it yourself?
  15. Webweave
    Webweave New
    Sorry I didn't understand. Where do I find the machine profile?
  16. Webweave
    Webweave New
    Can anyone else explain what he means by machine profile. I just did another job for the Workbee and the same problem is still there?
    It this a clue? Are there permissions on uploaded files? "Various Spacers" was an image I uploaded as a canvas.
  17. sharmstr
    You said " Openbuilds Workbee 1010 machine library". Which I assumed meant the machine profile since machine library isnt "post".
    Anyhow, its not the post. its the files you are using. Did you follow the link that swarfer posted above? Does PostGrbl.cps need a special group in Fusion 360?
