dri3 extension not supported
Discussion in 'Control Software' started by GigiG, Feb 8, 2023.
  1. GigiG
    GigiG New
    Hi all, I'm new here. I'm trying to install OpenBuilds Control on Linux Mint 20.3 but I got the following running OpenBuildsCONTROL-1.0.344 (both AppImage and deb package):
    [11564:0208/155406.582562:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
    [11525:0208/155406.960453:ERROR:browser_main_loop.cc(271)] Gdk: gdk_window_thaw_toplevel_updates: assertion 'window->update_and_descendants_freeze_count > 0' failed
    statusCode: 200
    What is wrong?
    Gigi
  3. GigiG
    GigiG New
    Removed/purged NVidia driver, now I'm on Intel Graphics. Running openbuildscontrol:
    > openbuildscontrol
    statusCode: 200
    that's all, but no new window opens ...
    Initial startup puts it in the system tray, launch the UI from there
  5. GigiG
    GigiG New
    It works! Thanks
    You'll ideally want to set it up so first run happens on boot - then its already waiting for you in the System tray (and its webserver and integration API already active)
