Easel origin question
Discussion in 'General Talk' started by KnockOnWood, Aug 13, 2023.
  1. KnockOnWood
    Every time I create a design to carve into my piece while using easel and I center the carving to material it works great on easel. Once I download the g-code to openbuilds control, it is moving the design to the top right for some reason. This just started happening. What could be causing this?
    #1 KnockOnWood, Aug 13, 2023
    did you also set the origin to the center of the work? centering the carving on the material is probably not the only thing you have to do.
    There are also various other things that affect where the drawing appears on the display. if you atttach the Gcode and a backup of your GRBL settings, and confirm that you have homed the machine, we can check further.
