Error 1, 2 and 20
Discussion in 'CAM' started by Tahir@NY, Sep 18, 2024.
  1. Tahir@NY
    Tahir@NY New
    I have been using the openbuild with grbl board hal 1.1 no problem. Came home after vacation :0 creaed some simple job in Vectric as usual.
    loaded the gcode, machines starts to cut and then it randomly throws Error 1, Erro 2 and Error 20
    I started troubleshooing and found that, when the vfd is ON, ShopVac is ON, and Spindle 2.2KW is ON, I get the rrors no matter what gcode.
    However, when Spindle is Off and everythig else is On. I do not get error message and machines cuts air without any issue.
    I would appreciate if you can guide me on how to troubleshoot further. I know its related to Spindle, just dont know what to do next.
    Thank you as always.
    ps: all my cables are farret chokes, VFD power goes through an EMI filter. USB cable is shielded
    the setup ran without any issue for along time
    Which controller? BlackBox X32?
  3. Tahir@NY
    Tahir@NY New
    My apologies. it is not a blackbox controller but a Chinese made (foxalien)
