Error:36
Discussion in 'General Talk' started by Rory Pentico, Oct 31, 2024.
  1. Rory Pentico
    Hi, I'm new to this whole thing of the world of CNC.
    I built me a CNC plasma machine. I've made a project and created a Gcode.
    with Openbuilds I would run the project simulated, and it would work fine. However,
    when I run the program, it would stop, and I will get Error:36.
    I don't know much about this and could use some help.
    Also, I've tried to upload a file, and this format won't let me.
    Again, any help would be greatly appreciated.
  2. Alex Chambers
    Well it literally means that there is a g-code word in your file that doesn't belong. Either there is a problem with the software you used to create the g-code, or the file is being corrupted in the transfer to your controller.
    So first tell us what software and post processor you used to create the g-code and upload the g-code file here so we can have a look at it (change the extension to *.txt if you have problems uploading it, it's just a txt file anyway).
    Second, tell us more about your plasma setup so those people who know more about this can tell you if that might be the source of your issue.
