Information: Configuration: OpenBuilds CNC : GRBL/BlackBox Information: Vendor: OpenBuilds Information: Posting intermediate data to 'C:\Users\smith\OneDrive\Desktop\1001.gcode' Information: Total number of warnings: 1 Error: Failed to post process. See below for details. ... Code page changed to '1252 (ANSI - Latin I)' Start time: Tuesday, April 2, 2024 6:24:18 PM Code page changed to '20127 (US-ASCII)' Post processor engine: 5.131.1 Configuration path: C:/Users/smith/AppData/Local/Autodesk/Autodesk Fusion 360/SMDFR2YQZZW7/W.login/M/D20220706538155051/CAMPosts/OpenbuildsFusion360PostGrbl.cps Include paths: C:/Users/smith/AppData/Local/Autodesk/Autodesk Fusion 360/SMDFR2YQZZW7/W.login/M/D20220706538155051/CAMPosts Configuration modification date: Tuesday, April 2, 2024 5:47:13 PM Output path: C:\Users\smith\OneDrive\Desktop\1001.gcode Checksum of intermediate NC data: 265fcdbca152e82555b604c912efcc1f Checksum of configuration: ee790eb427a50f639a79d354b94b7b3c Vendor url: Build List | OpenBuilds Legal: Copyright Openbuilds 2024 Generated by: Fusion CAM 2.0.18719 ... Warning: Invalid Work Coordinate System. Select WCS 1..6 in SETUPostProcess tab. Selecting default WCS1/G54 ############################################################################### Error: Failed to invoke method of class 'PostProcessor'. Error at line: 1136 (OpenbuildsFusion360PostGrbl.cps) Error in operation: '2D Contour3' Failed while processing onSection() for record 489. ############################################################################### Error: Failed to invoke function 'onSection'. Error: Failed to invoke 'onSection' in the post configuration. Error: Failed to execute configuration. Stop time: Tuesday, April 2, 2024 6:24:18 PM Post processing failed. What am I doing wrong?
got it, how do I turn off the homing cycle as im cutting multiple parts from this one gcode and would like to just manually set coordinates on my stock
It doesn't home. It does a Z clearance move in G53, but thats not going to interfere (that is best practice to allow safe moves without crashing into stock or clamps) Home once on powerup so the machine knows where it it. Then just SetZero or Probe where you need the origin to be
I dont have homing switches, so i manually home, as soon as i hit run program after zeroing my machine the z axix drives into my stock
Best option: Get switches. So worth it! Xtension Limit Switch Kit 2nd best, learn to Fake home properly How to 'Fake the home'
My issue is, I have my machine zeroed out where I want the job to start, As soon as I click run job, The z axis should raise to move to its first cut position, but it doesnt raise, it lowers and drags the bit through the stock to its first cut position (Made in : Autodesk CAM Post Processor) (G-Code optimized for Grbl 1.1 / BlackBox controller) (OpenBuilds CNC : GRBL/BlackBox) (Post-Processor : OpenbuildsFusion360PostGrbl.cps V1.0.41) (Units = inch) (Arcs are limited to the XY plane: if you want vertical arcs then) (edit allowedCircularPlanes in the CPS file) (Drawing name : Untitled) (Program Name : 58) (1 Operation (1 : 2D Contour1) ( Work Coordinate System : G54) ( Tool 2: Flat End Mill 2 Flutes, Diam = 0.25inch, Len = 0.75inch) ( Spindle : RPM = 5000) ( Machining time : 0h:2m:46s) G90 G94 G17 G20 (When using Fusion for Personal Use, the feedrate of rapid) (moves is reduced to match the feedrate of cutting moves,) (which can increase machining time. Unrestricted rapid moves) (are available with a Fusion Subscription.) (Operation 1 of 1 : 2D Contour1) G54 (This relies on homing, see Search Results for Query: G53 fusion | OpenBuilds ) G53 G0 Z0.3937 G0 X8.3099 Y16.2096 M3 S5000 G4 P1.8 G0 X8.3099 Y16.2096 Z0.6 F40 G1 Z0.2 Z0.0394 F13 Z-0.04 Y16.2093 Z-0.0439 F40 X8.31 Y16.2084 Z-0.0477 X8.3102 Y16.2069 Z-0.0514 X8.3104 Y16.2048 Z-0.0547 X8.3106 Y16.2023 Z-0.0577 X8.3109 Y16.1993 Z-0.0602 X8.3112 Y16.196 Z-0.0623 X8.3116 Y16.1924 Z-0.0638 X8.3119 Y16.1886 Z-0.0647 X8.3123 Y16.1847 Z-0.065 X8.3147 Y16.1598 Y16.1559 X8.3142 Y16.152 X8.313 Y16.1483 X8.3113 Y16.1447 X8.3091 Y16.1415 X8.3063 Y16.1387 X8.3032 Y16.1363 X8.2997 Y16.1345 X8.296 Y16.1332 X8.2922 Y16.1325 G3 X8.1855 Y15.9685 I0.0119 J-0.1244 G1 X8.8837 Y13.8802 G2 X8.9391 Y13.4962 I-1.0307 J-0.3446 G1 X8.7941 Y9.4991 X8.794 Y9.4946 Y9.4082 G3 X8.795 Y9.3927 I0.125 J0 G2 X8.3749 Y8.8326 I-0.5003 J-0.0624 G1 X6.7246 Y8.8605 G3 X6.1133 Y8.3934 I-0.0762 J-0.5338 G1 X6.0505 Y7.8897 G2 X5.6694 Y7.4424 I-0.5307 J0.0661 G1 X0.0052 Y7.6789 G3 X-0.104 Y7.4847 I-0.0052 J-0.1249 G1 X-0.057 Y7.4141 X-0.0103 Y7.3439 X0.0361 Y7.274 X0.0822 Y7.2045 X0.1281 Y7.1352 X0.1737 Y7.0663 X0.219 Y6.9976 X0.264 Y6.9293 X0.3088 Y6.8613 X0.3532 Y6.7937 X0.3974 Y6.7263 X0.4414 Y6.6593 X0.485 Y6.5926 X0.5284 Y6.5262 X0.5715 Y6.4601 X0.6143 Y6.3943 X0.6568 Y6.3289 X0.6991 Y6.2638 X0.7411 Y6.1989 X0.7828 Y6.1344 X0.8242 Y6.0703 X0.8654 Y6.0064 X0.9062 Y5.9429 X0.9468 Y5.8797 X0.9871 Y5.8168 X1.0272 Y5.7542 X1.0669 Y5.692 X1.1064 Y5.6301 X1.1456 Y5.5684 X1.1846 Y5.5072 X1.2232 Y5.4462 X1.2616 Y5.3855 X1.2997 Y5.3252 X1.3375 Y5.2652 X1.3751 Y5.2055 X1.4123 Y5.1462 X1.4493 Y5.0871 X1.486 Y5.0284 X1.5224 Y4.97 X1.5586 Y4.9119 X1.5945 Y4.8541 X1.6301 Y4.7967 X1.6654 Y4.7396 X1.7004 Y4.6828 X1.7352 Y4.6263 X1.7697 Y4.5702 X1.8039 Y4.5143 X1.8378 Y4.4589 X1.8715 Y4.4037 X1.9049 Y4.3488 X1.938 Y4.2943 X1.9708 Y4.2401 X2.0033 Y4.1863 X2.0356 Y4.1327 X2.0676 Y4.0794 X2.0993 Y4.0266 X2.1308 Y3.974 X2.1619 Y3.9217 X2.1928 Y3.8698 X2.2235 Y3.8182 X2.2538 Y3.767 X2.2839 Y3.716 X2.3137 Y3.6654 X2.3432 Y3.6151 X2.3724 Y3.5652 X2.4014 Y3.5155 X2.4301 Y3.4662 X2.4586 Y3.4173 X2.4867 Y3.3686 X2.5146 Y3.3203 X2.5422 Y3.2723 X2.5696 Y3.2247 X2.5966 Y3.1774 X2.6235 Y3.1304 X2.65 Y3.0837 X2.6763 Y3.0374 X2.7023 Y2.9914 X2.728 Y2.9457 X2.7534 Y2.9004 X2.7786 Y2.8554 X2.8036 Y2.8107 X2.8282 Y2.7664 X2.8526 Y2.7224 X2.8768 Y2.6787 X2.9007 Y2.6354 X2.9243 Y2.5924 X2.9476 Y2.5498 X2.9707 Y2.5074 X2.9935 Y2.4655 X3.0161 Y2.4238 X3.0384 Y2.3825 X3.0605 Y2.3415 X3.0822 Y2.3009 X3.1038 Y2.2606 X3.1251 Y2.2206 X3.1461 Y2.181 X3.1669 Y2.1417 X3.1874 Y2.1027 X3.2077 Y2.0641 X3.2277 Y2.0258 X3.2475 Y1.9879 X3.267 Y1.9503 X3.2863 Y1.9131 X3.3053 Y1.8762 X3.3241 Y1.8396 X3.3426 Y1.8034 X3.3609 Y1.7675 X3.379 Y1.7319 X3.3968 Y1.6967 X3.4144 Y1.6619 X3.4317 Y1.6274 X3.4488 Y1.5932 X3.4657 Y1.5594 X3.4824 Y1.5259 X3.4988 Y1.4927 X3.515 Y1.4599 X3.5309 Y1.4275 X3.5466 Y1.3954 X3.5621 Y1.3636 X3.5774 Y1.3322 X3.5925 Y1.3011 X3.6073 Y1.2704 X3.622 Y1.24 X3.6364 Y1.21 X3.6506 Y1.1803 X3.6646 Y1.151 X3.6783 Y1.122 X3.6919 Y1.0934 X3.7053 Y1.0651 X3.7184 Y1.0371 X3.7314 Y1.0095 X3.7442 Y0.9823 X3.7567 Y0.9554 X3.7691 Y0.9288 X3.7813 Y0.9026 X3.7933 Y0.8767 X3.8051 Y0.8512 X3.8167 Y0.8261 X3.8394 Y0.7767 X3.8614 Y0.7289 X3.8826 Y0.6824 Y0.6823 X3.9033 Y0.6372 X3.9232 Y0.5936 X3.9233 Y0.5934 X3.9427 Y0.5511 X3.9614 Y0.5102 X3.9615 Y0.51 X3.9796 Y0.4706 X3.9798 Y0.4703 X3.9974 Y0.4324 X3.9975 Y0.4321 X4.0146 Y0.3955 X4.0149 Y0.3949 X4.0315 Y0.3598 X4.0318 Y0.3592 X4.0479 Y0.3256 X4.0483 Y0.3249 X4.064 Y0.2927 X4.0645 Y0.2917 X4.0798 Y0.2609 X4.0805 Y0.2597 X4.0955 Y0.2304 X4.0963 Y0.2289 X4.111 Y0.2011 X4.112 Y0.1993 X4.1266 Y0.1729 X4.1279 Y0.1706 X4.1423 Y0.1457 X4.1438 Y0.1433 X4.1581 Y0.1198 X4.16 Y0.1168 X4.1743 Y0.0947 X4.1767 Y0.0912 X4.1911 Y0.0706 X4.1939 Y0.0667 X4.2084 Y0.0476 X4.2121 Y0.043 X4.2269 Y0.0252 X4.2313 Y0.0202 X4.2464 Y0.0039 X4.2515 Y-0.0013 X4.267 Y-0.0162 X4.2733 Y-0.0218 X4.2895 Y-0.0353 X4.293 Y-0.0381 X4.2965 Y-0.0408 X4.3133 Y-0.0529 X4.3194 Y-0.0571 X4.3281 Y-0.0626 X4.332 Y-0.065 X4.3408 Y-0.0702 X4.3454 Y-0.0727 X4.3546 Y-0.0776 X4.3588 Y-0.0797 X4.3682 Y-0.0843 X4.3728 Y-0.0864 X4.3824 Y-0.0905 X4.387 Y-0.0924 X4.3969 Y-0.0962 X4.4014 Y-0.0979 X4.4116 Y-0.1014 X4.4161 Y-0.1029 X4.4266 Y-0.106 X4.431 Y-0.1073 X4.4418 Y-0.1101 X4.4461 Y-0.1111 X4.4572 Y-0.1136 X4.4614 Y-0.1145 X4.4728 Y-0.1166 X4.4768 Y-0.1173 X4.4886 Y-0.1192 X4.4924 Y-0.1197 X4.5046 Y-0.1212 X4.5082 Y-0.1216 X4.5207 Y-0.1228 X4.5242 Y-0.1231 X4.5371 Y-0.1239 X4.5403 Y-0.1241 X4.5537 Y-0.1246 X4.5567 Y-0.1247 X4.5704 Y-0.125 X4.5732 X4.5875 Y-0.1249 X4.5901 X4.6047 Y-0.1245 X4.6071 Y-0.1244 X4.6222 Y-0.1237 X4.6245 Y-0.1236 X4.64 Y-0.1226 X4.6421 Y-0.1225 X4.6581 Y-0.1212 X4.66 Y-0.121 X4.6765 Y-0.1194 X4.6782 Y-0.1192 X4.6952 Y-0.1174 X4.6969 Y-0.1172 X4.7143 Y-0.115 X4.7158 Y-0.1148 X4.7337 Y-0.1124 X4.7351 Y-0.1122 X4.7534 Y-0.1095 X4.7548 Y-0.1093 X4.7736 Y-0.1063 X4.7748 Y-0.1061 X4.7942 Y-0.1028 X4.7953 Y-0.1026 X4.8151 Y-0.0991 X4.8161 Y-0.0989 X4.8364 Y-0.0951 X4.8374 Y-0.0949 X4.8581 Y-0.0909 X4.859 Y-0.0907 X4.8802 Y-0.0864 X4.8811 Y-0.0862 X4.9027 Y-0.0817 X4.9035 Y-0.0815 X4.9256 Y-0.0767 X4.9263 Y-0.0766 X4.9489 Y-0.0715 X4.9495 Y-0.0714 X4.9726 Y-0.0661 X4.9732 Y-0.066 X4.9967 Y-0.0605 X4.9972 Y-0.0604 X5.0211 Y-0.0547 X5.0217 Y-0.0545 X5.0459 Y-0.0486 X5.0464 Y-0.0485 X5.0711 Y-0.0424 X5.0716 Y-0.0423 X5.0966 Y-0.0359 X5.0971 Y-0.0358 X5.1225 Y-0.0293 X5.1229 Y-0.0292 X5.1487 Y-0.0225 X5.1493 Y-0.0223 X5.2019 Y-0.0083 X5.2026 Y-0.0081 X5.2564 Y0.0066 X5.2571 Y0.0068 X5.312 Y0.0221 X5.3126 Y0.0223 X5.3685 Y0.0382 X5.3691 Y0.0384 X5.4258 Y0.0549 X5.4264 Y0.0551 X5.4838 Y0.0721 X5.4844 Y0.0722 X5.5423 Y0.0897 X5.5428 Y0.0898 X5.6011 Y0.1077 X5.6019 Y0.1079 X5.7191 Y0.1446 X5.7202 Y0.1449 X5.8371 Y0.1827 X5.8379 Y0.183 X5.8959 Y0.2021 X5.8964 Y0.2023 X5.954 Y0.2215 X5.9545 Y0.2217 X6.0114 Y0.2411 X6.0119 Y0.2413 X6.0681 Y0.2606 X6.0687 Y0.2608 X6.1239 Y0.2802 X6.1245 Y0.2804 X6.1787 Y0.2998 X6.1793 Y0.3 X6.2325 Y0.3192 X6.2331 Y0.3195 X6.2851 Y0.3386 X6.2858 Y0.3388 X6.3364 Y0.3578 X6.3371 Y0.3581 X6.3864 Y0.3769 X6.3871 Y0.3772 X6.4351 Y0.3958 X6.4358 Y0.396 X6.4823 Y0.4144 X6.483 Y0.4147 X6.5281 Y0.4328 X6.5288 Y0.4331 X6.5725 Y0.4509 X6.5731 Y0.4512 X6.6154 Y0.4688 X6.616 Y0.469 X6.6569 Y0.4863 X6.6575 Y0.4865 X6.697 Y0.5035 X6.6976 Y0.5037 X6.7359 Y0.5203 X6.7364 Y0.5206 X6.7734 Y0.5369 X6.7738 Y0.537 X6.8098 Y0.553 X6.8101 Y0.5531 X6.8451 Y0.5688 X6.8452 X6.8793 Y0.5841 X6.8794 Y0.5842 X6.9126 Y0.5991 X6.9452 Y0.6137 X6.977 Y0.6279 X7.0082 Y0.6416 X7.0699 Y0.6681 X7.1316 Y0.6935 X7.1622 Y0.7055 X7.1935 Y0.7174 X7.2252 Y0.729 X7.2577 Y0.7405 X7.2909 Y0.7517 X7.3251 Y0.7627 X7.3602 Y0.7736 X7.3966 Y0.7844 X7.434 Y0.795 X7.4727 Y0.8055 X7.5127 Y0.8159 X7.5541 Y0.8261 X7.5967 Y0.8363 X7.6406 Y0.8463 X7.6858 Y0.8562 X7.7323 Y0.866 X7.78 Y0.8757 X7.8289 Y0.8854 X7.8789 Y0.8948 X7.9299 Y0.9042 X7.9819 Y0.9135 X8.0349 Y0.9226 X8.0886 Y0.9317 X8.1431 Y0.9406 X8.1983 Y0.9493 X8.2539 Y0.958 X8.3669 Y0.9749 X8.4809 Y0.9911 X8.5952 Y1.0068 X8.7092 Y1.0217 X8.8223 Y1.0359 X8.8781 Y1.0427 X8.9335 Y1.0493 X8.9884 Y1.0557 X9.0426 Y1.0619 X9.0963 Y1.0678 X9.1492 Y1.0735 X9.2014 Y1.0789 X9.2528 Y1.0841 X9.3035 Y1.089 X9.3533 Y1.0936 X9.4025 Y1.098 X9.4508 Y1.1021 X9.4984 Y1.1059 X9.5452 Y1.1094 X9.5914 Y1.1125 X9.6368 Y1.1154 X9.6816 Y1.118 X9.7258 Y1.1202 X9.7695 Y1.1221 X9.8126 Y1.1236 X9.8553 Y1.1248 X9.8976 Y1.1257 X9.9396 Y1.1262 X9.9813 Y1.1263 X10.0228 Y1.1261 X10.0638 Y1.1255 X10.1469 Y1.1231 X10.188 Y1.1214 X10.2294 Y1.1192 X10.2711 Y1.1167 X10.313 Y1.1137 X10.3553 Y1.1103 X10.398 Y1.1066 X10.4411 Y1.1023 X10.4847 Y1.0977 X10.5288 Y1.0926 X10.5736 Y1.0871 X10.619 Y1.0812 X10.665 Y1.0748 X10.7118 Y1.0679 X10.7594 Y1.0606 X10.8078 Y1.0529 X10.8569 Y1.0447 X10.9069 Y1.036 X10.9578 Y1.0269 X11.0097 Y1.0173 X11.0624 Y1.0072 X11.116 Y0.9966 X11.1707 Y0.9856 X11.2262 Y0.9741 X11.2828 Y0.9622 X11.3404 Y0.9497 X11.3991 Y0.9368 X11.4587 Y0.9234 X11.5193 Y0.9096 X11.5811 Y0.8952 X11.6438 Y0.8804 X11.7076 Y0.8651 X11.7727 Y0.8493 G3 X11.9272 Y0.9726 I0.0295 J0.1215 G1 X11.9239 Y1.224 X11.9212 Y1.4754 X11.9191 Y1.7269 X11.9176 Y1.9783 X11.9168 Y2.2298 X11.9165 Y2.4813 X11.9169 Y2.7327 X11.9179 Y2.9842 X11.9195 Y3.2356 X11.9217 Y3.4871 X11.9245 Y3.7385 X11.928 Y3.9899 X11.932 Y4.2414 X11.9367 Y4.4928 X11.942 Y4.7442 X11.9478 Y4.9956 X11.9544 Y5.2469 X11.9615 Y5.4983 X11.9692 Y5.7496 X11.9776 Y6.001 X11.9865 Y6.2523 X11.9961 Y6.5035 X12.0063 Y6.7548 X12.0171 Y7.006 X12.0285 Y7.2572 X12.0405 Y7.5084 X12.0532 Y7.7595 X12.0664 Y8.0106 X12.0803 Y8.2617 X12.0948 Y8.5127 X12.1099 Y8.7637 X12.1256 Y9.0147 X12.1419 Y9.2656 X12.1589 Y9.5165 X12.1764 Y9.7674 X12.1946 Y10.0182 X12.2133 Y10.2689 X12.2327 Y10.5196 X12.2527 Y10.7703 X12.2733 Y11.0209 X12.2945 Y11.2715 X12.3164 Y11.522 X12.3388 Y11.7724 X12.3619 Y12.0228 X12.3856 Y12.2732 X12.4098 Y12.5234 X12.4347 Y12.7737 X12.4602 Y13.0238 X12.4863 Y13.2739 X12.5131 Y13.524 G2 X12.5276 Y13.6189 I1.0805 J-0.117 G1 X12.9776 Y15.8847 G3 X12.855 Y16.0341 I-0.1226 J0.0244 G1 X11.0567 G2 X11.0173 Y16.0348 I-0.0003 J1.0868 G1 X8.3086 Y16.133 G3 X8.2922 Y16.1325 I-0.0045 J-0.1249 G1 X8.2882 X8.2844 Y16.133 X8.2806 Y16.1342 X8.2771 Y16.1359 X8.2739 Y16.1381 X8.271 Y16.1409 X8.2687 Y16.144 X8.2668 Y16.1475 X8.2656 Y16.1512 X8.2649 Y16.155 X8.2625 Y16.1799 X8.2621 Y16.1838 Z-0.0647 X8.2618 Y16.1876 Z-0.0638 X8.2614 Y16.1912 Z-0.0623 X8.2611 Y16.1946 Z-0.0602 X8.2608 Y16.1975 Z-0.0577 X8.2606 Y16.2001 Z-0.0547 X8.2604 Y16.2021 Z-0.0513 X8.2603 Y16.2036 Z-0.0477 X8.2602 Y16.2045 Z-0.0439 X8.2601 Y16.2048 Z-0.04 Z0.2 X8.3099 Y16.2096 Z-0.0256 F13 Z-0.075 Y16.2093 Z-0.0789 F40 X8.31 Y16.2084 Z-0.0827 X8.3102 Y16.2069 Z-0.0864 X8.3104 Y16.2048 Z-0.0897 X8.3106 Y16.2023 Z-0.0927 X8.3109 Y16.1993 Z-0.0952 X8.3112 Y16.196 Z-0.0973 X8.3116 Y16.1924 Z-0.0988 X8.3119 Y16.1886 Z-0.0997 X8.3123 Y16.1847 Z-0.1 X8.3147 Y16.1598 Y16.1559 X8.3142 Y16.152 X8.313 Y16.1483 X8.3113 Y16.1447 X8.3091 Y16.1415 X8.3063 Y16.1387 X8.3032 Y16.1363 X8.2997 Y16.1345 X8.296 Y16.1332 X8.2922 Y16.1325 G3 X8.1855 Y15.9685 I0.0119 J-0.1244 G1 X8.8837 Y13.8802 G2 X8.9391 Y13.4962 I-1.0307 J-0.3446 G1 X8.7941 Y9.4991 X8.794 Y9.4946 Y9.4082 G3 X8.795 Y9.3927 I0.125 J0 G2 X8.3749 Y8.8326 I-0.5003 J-0.0624 G1 X6.7246 Y8.8605 G3 X6.1133 Y8.3934 I-0.0762 J-0.5338 G1 X6.0505 Y7.8897 G2 X5.6694 Y7.4424 I-0.5307 J0.0661 G1 X0.0052 Y7.6789 G3 X-0.104 Y7.4847 I-0.0052 J-0.1249 G1 X-0.057 Y7.4141 X-0.0103 Y7.3439 X0.0361 Y7.274 X0.0822 Y7.2045 X0.1281 Y7.1352 X0.1737 Y7.0663 X0.219 Y6.9976 X0.264 Y6.9293 X0.3088 Y6.8613 X0.3532 Y6.7937 X0.3974 Y6.7263 X0.4414 Y6.6593 X0.485 Y6.5926 X0.5284 Y6.5262 X0.5715 Y6.4601 X0.6143 Y6.3943 X0.6568 Y6.3289 X0.6991 Y6.2638 X0.7411 Y6.1989 X0.7828 Y6.1344 X0.8242 Y6.0703 X0.8654 Y6.0064 X0.9062 Y5.9429 X0.9468 Y5.8797 X0.9871 Y5.8168 X1.0272 Y5.7542 X1.0669 Y5.692 X1.1064 Y5.6301 X1.1456 Y5.5684 X1.1846 Y5.5072 X1.2232 Y5.4462 X1.2616 Y5.3855 X1.2997 Y5.3252 X1.3375 Y5.2652 X1.3751 Y5.2055 X1.4123 Y5.1462 X1.4493 Y5.0871 X1.486 Y5.0284 X1.5224 Y4.97 X1.5586 Y4.9119 X1.5945 Y4.8541 X1.6301 Y4.7967 X1.6654 Y4.7396 X1.7004 Y4.6828 X1.7352 Y4.6263 X1.7697 Y4.5702 X1.8039 Y4.5143 X1.8378 Y4.4589 X1.8715 Y4.4037 X1.9049 Y4.3488 X1.938 Y4.2943 X1.9708 Y4.2401 X2.0033 Y4.1863 X2.0356 Y4.1327 X2.0676 Y4.0794 X2.0993 Y4.0266 X2.1308 Y3.974 X2.1619 Y3.9217 X2.1928 Y3.8698 X2.2235 Y3.8182 X2.2538 Y3.767 X2.2839 Y3.716 X2.3137 Y3.6654 X2.3432 Y3.6151 X2.3724 Y3.5652 X2.4014 Y3.5155 X2.4301 Y3.4662 X2.4586 Y3.4173 X2.4867 Y3.3686 X2.5146 Y3.3203 X2.5422 Y3.2723 X2.5696 Y3.2247 X2.5966 Y3.1774 X2.6235 Y3.1304 X2.65 Y3.0837 X2.6763 Y3.0374 X2.7023 Y2.9914 X2.728 Y2.9457 X2.7534 Y2.9004 X2.7786 Y2.8554 X2.8036 Y2.8107 X2.8282 Y2.7664 X2.8526 Y2.7224 X2.8768 Y2.6787 X2.9007 Y2.6354 X2.9243 Y2.5924 X2.9476 Y2.5498 X2.9707 Y2.5074 X2.9935 Y2.4655 X3.0161 Y2.4238 X3.0384 Y2.3825 X3.0605 Y2.3415 X3.0822 Y2.3009 X3.1038 Y2.2606 X3.1251 Y2.2206 X3.1461 Y2.181 X3.1669 Y2.1417 X3.1874 Y2.1027 X3.2077 Y2.0641 X3.2277 Y2.0258 X3.2475 Y1.9879 X3.267 Y1.9503 X3.2863 Y1.9131 X3.3053 Y1.8762 X3.3241 Y1.8396 X3.3426 Y1.8034 X3.3609 Y1.7675 X3.379 Y1.7319 X3.3968 Y1.6967 X3.4144 Y1.6619 X3.4317 Y1.6274 X3.4488 Y1.5932 X3.4657 Y1.5594 X3.4824 Y1.5259 X3.4988 Y1.4927 X3.515 Y1.4599 X3.5309 Y1.4275 X3.5466 Y1.3954 X3.5621 Y1.3636 X3.5774 Y1.3322 X3.5925 Y1.3011 X3.6073 Y1.2704 X3.622 Y1.24 X3.6364 Y1.21 X3.6506 Y1.1803 X3.6646 Y1.151 X3.6783 Y1.122 X3.6919 Y1.0934 X3.7053 Y1.0651 X3.7184 Y1.0371 X3.7314 Y1.0095 X3.7442 Y0.9823 X3.7567 Y0.9554 X3.7691 Y0.9288 X3.7813 Y0.9026 X3.7933 Y0.8767 X3.8051 Y0.8512 X3.8167 Y0.8261 X3.8394 Y0.7767 X3.8614 Y0.7289 X3.8826 Y0.6824 Y0.6823 X3.9033 Y0.6372 X3.9232 Y0.5936 X3.9233 Y0.5934 X3.9427 Y0.5511 X3.9614 Y0.5102 X3.9615 Y0.51 X3.9796 Y0.4706 X3.9798 Y0.4703 X3.9974 Y0.4324 X3.9975 Y0.4321 X4.0146 Y0.3955 X4.0149 Y0.3949 X4.0315 Y0.3598 X4.0318 Y0.3592 X4.0479 Y0.3256 X4.0483 Y0.3249 X4.064 Y0.2927 X4.0645 Y0.2917 X4.0798 Y0.2609 X4.0805 Y0.2597 X4.0955 Y0.2304 X4.0963 Y0.2289 X4.111 Y0.2011 X4.112 Y0.1993 X4.1266 Y0.1729 X4.1279 Y0.1706 X4.1423 Y0.1457 X4.1438 Y0.1433 X4.1581 Y0.1198 X4.16 Y0.1168 X4.1743 Y0.0947 X4.1767 Y0.0912 X4.1911 Y0.0706 X4.1939 Y0.0667 X4.2084 Y0.0476 X4.2121 Y0.043 X4.2269 Y0.0252 X4.2313 Y0.0202 X4.2464 Y0.0039 X4.2515 Y-0.0013 X4.267 Y-0.0162 X4.2733 Y-0.0218 X4.2895 Y-0.0353 X4.293 Y-0.0381 X4.2965 Y-0.0408 X4.3133 Y-0.0529 X4.3194 Y-0.0571 X4.3281 Y-0.0626 X4.332 Y-0.065 X4.3408 Y-0.0702 X4.3454 Y-0.0727 X4.3546 Y-0.0776 X4.3588 Y-0.0797 X4.3682 Y-0.0843 X4.3728 Y-0.0864 X4.3824 Y-0.0905 X4.387 Y-0.0924 X4.3969 Y-0.0962 X4.4014 Y-0.0979 X4.4116 Y-0.1014 X4.4161 Y-0.1029 X4.4266 Y-0.106 X4.431 Y-0.1073 X4.4418 Y-0.1101 X4.4461 Y-0.1111 X4.4572 Y-0.1136 X4.4614 Y-0.1145 X4.4728 Y-0.1166 X4.4768 Y-0.1173 X4.4886 Y-0.1192 X4.4924 Y-0.1197 X4.5046 Y-0.1212 X4.5082 Y-0.1216 X4.5207 Y-0.1228 X4.5242 Y-0.1231 X4.5371 Y-0.1239 X4.5403 Y-0.1241 X4.5537 Y-0.1246 X4.5567 Y-0.1247 X4.5704 Y-0.125 X4.5732 X4.5875 Y-0.1249 X4.5901 X4.6047 Y-0.1245 X4.6071 Y-0.1244 X4.6222 Y-0.1237 X4.6245 Y-0.1236 X4.64 Y-0.1226 X4.6421 Y-0.1225 X4.6581 Y-0.1212 X4.66 Y-0.121 X4.6765 Y-0.1194 X4.6782 Y-0.1192 X4.6952 Y-0.1174 X4.6969 Y-0.1172 X4.7143 Y-0.115 X4.7158 Y-0.1148 X4.7337 Y-0.1124 X4.7351 Y-0.1122 X4.7534 Y-0.1095 X4.7548 Y-0.1093 X4.7736 Y-0.1063 X4.7748 Y-0.1061 X4.7942 Y-0.1028 X4.7953 Y-0.1026 X4.8151 Y-0.0991 X4.8161 Y-0.0989 X4.8364 Y-0.0951 X4.8374 Y-0.0949 X4.8581 Y-0.0909 X4.859 Y-0.0907 X4.8802 Y-0.0864 X4.8811 Y-0.0862 X4.9027 Y-0.0817 X4.9035 Y-0.0815 X4.9256 Y-0.0767 X4.9263 Y-0.0766 X4.9489 Y-0.0715 X4.9495 Y-0.0714 X4.9726 Y-0.0661 X4.9732 Y-0.066 X4.9967 Y-0.0605 X4.9972 Y-0.0604 X5.0211 Y-0.0547 X5.0217 Y-0.0545 X5.0459 Y-0.0486 X5.0464 Y-0.0485 X5.0711 Y-0.0424 X5.0716 Y-0.0423 X5.0966 Y-0.0359 X5.0971 Y-0.0358 X5.1225 Y-0.0293 X5.1229 Y-0.0292 X5.1487 Y-0.0225 X5.1493 Y-0.0223 X5.2019 Y-0.0083 X5.2026 Y-0.0081 X5.2564 Y0.0066 X5.2571 Y0.0068 X5.312 Y0.0221 X5.3126 Y0.0223 X5.3685 Y0.0382 X5.3691 Y0.0384 X5.4258 Y0.0549 X5.4264 Y0.0551 X5.4838 Y0.0721 X5.4844 Y0.0722 X5.5423 Y0.0897 X5.5428 Y0.0898 X5.6011 Y0.1077 X5.6019 Y0.1079 X5.7191 Y0.1446 X5.7202 Y0.1449 X5.8371 Y0.1827 X5.8379 Y0.183 X5.8959 Y0.2021 X5.8964 Y0.2023 X5.954 Y0.2215 X5.9545 Y0.2217 X6.0114 Y0.2411 X6.0119 Y0.2413 X6.0681 Y0.2606 X6.0687 Y0.2608 X6.1239 Y0.2802 X6.1245 Y0.2804 X6.1787 Y0.2998 X6.1793 Y0.3 X6.2325 Y0.3192 X6.2331 Y0.3195 X6.2851 Y0.3386 X6.2858 Y0.3388 X6.3364 Y0.3578 X6.3371 Y0.3581 X6.3864 Y0.3769 X6.3871 Y0.3772 X6.4351 Y0.3958 X6.4358 Y0.396 X6.4823 Y0.4144 X6.483 Y0.4147 X6.5281 Y0.4328 X6.5288 Y0.4331 X6.5725 Y0.4509 X6.5731 Y0.4512 X6.6154 Y0.4688 X6.616 Y0.469 X6.6569 Y0.4863 X6.6575 Y0.4865 X6.697 Y0.5035 X6.6976 Y0.5037 X6.7359 Y0.5203 X6.7364 Y0.5206 X6.7734 Y0.5369 X6.7738 Y0.537 X6.8098 Y0.553 X6.8101 Y0.5531 X6.8451 Y0.5688 X6.8452 X6.8793 Y0.5841 X6.8794 Y0.5842 X6.9126 Y0.5991 X6.9452 Y0.6137 X6.977 Y0.6279 X7.0082 Y0.6416 X7.0699 Y0.6681 X7.1316 Y0.6935 X7.1622 Y0.7055 X7.1935 Y0.7174 X7.2252 Y0.729 X7.2577 Y0.7405 X7.2909 Y0.7517 X7.3251 Y0.7627 X7.3602 Y0.7736 X7.3966 Y0.7844 X7.434 Y0.795 X7.4727 Y0.8055 X7.5127 Y0.8159 X7.5541 Y0.8261 X7.5967 Y0.8363 X7.6406 Y0.8463 X7.6858 Y0.8562 X7.7323 Y0.866 X7.78 Y0.8757 X7.8289 Y0.8854 X7.8789 Y0.8948 X7.9299 Y0.9042 X7.9819 Y0.9135 X8.0349 Y0.9226 X8.0886 Y0.9317 X8.1431 Y0.9406 X8.1983 Y0.9493 X8.2539 Y0.958 X8.3669 Y0.9749 X8.4809 Y0.9911 X8.5952 Y1.0068 X8.7092 Y1.0217 X8.8223 Y1.0359 X8.8781 Y1.0427 X8.9335 Y1.0493 X8.9884 Y1.0557 X9.0426 Y1.0619 X9.0963 Y1.0678 X9.1492 Y1.0735 X9.2014 Y1.0789 X9.2528 Y1.0841 X9.3035 Y1.089 X9.3533 Y1.0936 X9.4025 Y1.098 X9.4508 Y1.1021 X9.4984 Y1.1059 X9.5452 Y1.1094 X9.5914 Y1.1125 X9.6368 Y1.1154 X9.6816 Y1.118 X9.7258 Y1.1202 X9.7695 Y1.1221 X9.8126 Y1.1236 X9.8553 Y1.1248 X9.8976 Y1.1257 X9.9396 Y1.1262 X9.9813 Y1.1263 X10.0228 Y1.1261 X10.0638 Y1.1255 X10.1469 Y1.1231 X10.188 Y1.1214 X10.2294 Y1.1192 X10.2711 Y1.1167 X10.313 Y1.1137 X10.3553 Y1.1103 X10.398 Y1.1066 X10.4411 Y1.1023 X10.4847 Y1.0977 X10.5288 Y1.0926 X10.5736 Y1.0871 X10.619 Y1.0812 X10.665 Y1.0748 X10.7118 Y1.0679 X10.7594 Y1.0606 X10.8078 Y1.0529 X10.8569 Y1.0447 X10.9069 Y1.036 X10.9578 Y1.0269 X11.0097 Y1.0173 X11.0624 Y1.0072 X11.116 Y0.9966 X11.1707 Y0.9856 X11.2262 Y0.9741 X11.2828 Y0.9622 X11.3404 Y0.9497 X11.3991 Y0.9368 X11.4587 Y0.9234 X11.5193 Y0.9096 X11.5811 Y0.8952 X11.6438 Y0.8804 X11.7076 Y0.8651 X11.7727 Y0.8493 G3 X11.9272 Y0.9726 I0.0295 J0.1215 G1 X11.9239 Y1.224 X11.9212 Y1.4754 X11.9191 Y1.7269 X11.9176 Y1.9783 X11.9168 Y2.2298 X11.9165 Y2.4813 X11.9169 Y2.7327 X11.9179 Y2.9842 X11.9195 Y3.2356 X11.9217 Y3.4871 X11.9245 Y3.7385 X11.928 Y3.9899 X11.932 Y4.2414 X11.9367 Y4.4928 X11.942 Y4.7442 X11.9478 Y4.9956 X11.9544 Y5.2469 X11.9615 Y5.4983 X11.9692 Y5.7496 X11.9776 Y6.001 X11.9865 Y6.2523 X11.9961 Y6.5035 X12.0063 Y6.7548 X12.0171 Y7.006 X12.0285 Y7.2572 X12.0405 Y7.5084 X12.0532 Y7.7595 X12.0664 Y8.0106 X12.0803 Y8.2617 X12.0948 Y8.5127 X12.1099 Y8.7637 X12.1256 Y9.0147 X12.1419 Y9.2656 X12.1589 Y9.5165 X12.1764 Y9.7674 X12.1946 Y10.0182 X12.2133 Y10.2689 X12.2327 Y10.5196 X12.2527 Y10.7703 X12.2733 Y11.0209 X12.2945 Y11.2715 X12.3164 Y11.522 X12.3388 Y11.7724 X12.3619 Y12.0228 X12.3856 Y12.2732 X12.4098 Y12.5234 X12.4347 Y12.7737 X12.4602 Y13.0238 X12.4863 Y13.2739 X12.5131 Y13.524 G2 X12.5276 Y13.6189 I1.0805 J-0.117 G1 X12.9776 Y15.8847 G3 X12.855 Y16.0341 I-0.1226 J0.0244 G1 X11.0567 G2 X11.0173 Y16.0348 I-0.0003 J1.0868 G1 X8.3086 Y16.133 G3 X8.2922 Y16.1325 I-0.0045 J-0.1249 G1 X8.2882 X8.2844 Y16.133 X8.2806 Y16.1342 X8.2771 Y16.1359 X8.2739 Y16.1381 X8.271 Y16.1409 X8.2687 Y16.144 X8.2668 Y16.1475 X8.2656 Y16.1512 X8.2649 Y16.155 X8.2625 Y16.1799 X8.2621 Y16.1838 Z-0.0997 X8.2618 Y16.1876 Z-0.0988 X8.2614 Y16.1912 Z-0.0973 X8.2611 Y16.1946 Z-0.0952 X8.2608 Y16.1975 Z-0.0927 X8.2606 Y16.2001 Z-0.0897 X8.2604 Y16.2021 Z-0.0863 X8.2603 Y16.2036 Z-0.0827 X8.2602 Y16.2045 Z-0.0789 X8.2601 Y16.2048 Z-0.075 G0 Z0.6 (This relies on homing, see Search Results for Query: G53 fusion | OpenBuilds ) G53 G0 Z0.3937 M5 G0 X0 Y0 M30
Correct, needs a HOME up and away - get the switches, or learn to fake it But really, get the switches. Setup Homing. You'll just have a much better time if you home. Consistency for recoveries. Machine knows where it is to use G53 moves. Just better! Worth the couple bucks! As it says, right there in the output
Hi @Daniel Smith, in reply to your private message, I started to reply to this post but go interrupted but @Peter Van Der Walt has given you the advice I would have said. Homing your machine so that you have a reliable reference point in your MACHINE co-ordinate system (the WORKPLACE co-ordinate system zero you are setting is stored as an offset from the MACHINE home position) is pretty important if you want to be able to go back to the same point where you set the WORKPLACE zero. Alex.
then you need to be following the proper 'fake the home' method else it (the machine, nor gcode) will not work correctly please read How to 'Fake the home' Home, Fusion360 and G53 Z moves
well, you see, machines do not work like that..... they have a Machine Coordinate System (MCS), this is set by homing, or in GRBL's case, whereever it resets or turns on all other coordiante systems, called Work Coordinate Ssytems, are offsets from the MCS. without a proper home, the offsets won't work the way Gcode expects. All a part of industry standards that have been figured out after many expensive crashes (-: so the process in a nutshell: turn machine on home load Gcode jog to where the PART origin has been set in the CAM on the material, and setZero or probe there. This sets those WCS offsets. check that gcode display makes sense relative to the workpiece run gcode
