Firmware update failure.... linux read only tmp mount.
Discussion in 'OpenBuilds Bug Report' started by Simon Convey, Jul 27, 2023.
  1. Simon Convey
    I was just updating the firmware using CONTROL v1.0.370. Linux console suggest that we need a writable tmp area to execute the chmod......
    {"port":"/dev/ttyUSB0","file":"grblhal-grbl3axis.bin","erase":false,"customImg":false} null 4
    Flashing BlackBoxX32 on /dev/ttyUSB0 with file: /tmp/.mount_OpenBueL3VVc/resources/app.asar.unpacked/grblhal-grbl3axis.bin
    Error: EROFS: read-only file system, chmod '/tmp/.mount_OpenBueL3VVc/resources/app.asar.unpacked/esptool.py'
    at Object.chmodSync (node:fs:1888:3)
    at flashGrblHal (/tmp/.mount_OpenBueL3VVc/resources/app.asar/index.js:3489:8)
    at Socket.<anonymous> (/tmp/.mount_OpenBueL3VVc/resources/app.asar/index.js:992:5)
    at Socket.emit (node:events:513:28)
    at Socket.emitUntyped (/tmp/.mount_OpenBueL3VVc/resources/app.asar/node_modules/socket.io/dist/typed-events.js:69:22)
    at /tmp/.mount_OpenBueL3VVc/resources/app.asar/node_modules/socket.io/dist/socket.js:703:39
    at process.processTicksAndRejections (node:internal/process/task_queues:77:11) {
    errno: -30,
    syscall: 'chmod',
    code: 'EROFS',
    path: '/tmp/.mount_OpenBueL3VVc/resources/app.asar.unpacked/esptool.py'
    Thanks for the report. If you have a Windows PC nearby, for now would be best. Or try the Deb version (AppImages runs in sandbox)
