First 3D Carving Project on Hardwood
Discussion in 'CNC Mills/Routers' started by Scott Thompson, Aug 11, 2021.
  1. Scott Thompson
    This project turned out pretty good except for the artifacts seen in the photos. I used a 1/16" tapered bull nose. Did I set up the machine wrong or is this normal for hardwood (oak I think)?
    20210809_171136 (Medium).jpg 20210809_171136 (Medium).jpg 20210810_113453 (Medium).jpg 20210810_113546 (Medium).jpg 20210810_113615 (Medium).jpg
    Be patient, help will come. I don’t have the answer but sooner or later someone with the answer will chime in.
  3. Scott Thompson
    Generic reply, but should cover it:
    - play with speeds and feeds and other cut parameters - something might just be a little off
    - try a different material
    - is the endmill the correct geometry / flute count for your material
    - is the endmill sharp
    - do a final cleanup pass
  5. Scott Thompson
    Thanks for the advice Peter. A few comments regarding your reply. The End Mill is brand new and has two flutes. A finishing pass sounds like a great idea. To do a finishing pass would I simply rerun the same G-Code or would I modify it somewhat?
    Thanks,
    Scott
    Depends on the setup and CAM
    The right way is to leave a little stock, and CAM up a finishing pass properly. Rerunning it may work - but less ideal - also depends on how well you will be able to reestablish Zero/Origin too
    Scott Thompson likes this.
  7. Giarc
    Nice piece of wood, but not oak. ;)
    Did you only use the 1/16" inch ball nose, or did you rough it out with a larger one? What software are you using?
    When I do carves, I rough it out with a 1/4" (or larger if it is a big project) ball nose and it removes most of what needs to be removed. Then I follow up with a 1/8" ball nose for the finishing pass and usually it will be 90 degrees to the roughing pass. Rarely have I needed smaller than 1/8" ball nose. On small projects I have used as small as a 2mm ball nose for the finishing past. Yours looks like it has a lot of small details so the 1/16" was probably the right choice.
  8. JustinTime
    JustinTime Veteran
    I noticed that the problem is on the bottom of the Y axis mostly, nothing on the top. Could it be a deflection of the bit do to the grain of the wood?
    Rick 2.0 likes this.
  9. Scott Thompson
    Giarc,
    Thanks for responding to my post. Hers are the answers to your questions:
    Oh can you tell me the species?
    Yes … roughed out with a 1/8" end mill
    Carveco Maker formally Artcam
    Regards,
    Scott
  10. Scott Thompson
    Not sure but I am having problems with the Y axis. The machine is a LEAD CNC 1510 and I am getting a lot of lead screw slap because the leads screws are not under tension. I am trying to purchase a tension kit like the Tingle Tension System but so far not luck.
    Scott
  11. Peter Van Der Walt
  12. Scott Thompson
