Flattening Wizard Freezes up
Discussion in 'Control Software' started by LokiVenter, Nov 15, 2020.
Tags:
  1. LokiVenter
    Hi
    Used the flattening wizard 3 times before no issues. Now for some unknown reason it just freezes up when i click proceed.
    I have updated today hoping this would solve the problem but no luck.
    Any advice would be much appreciated.
    Regards
  2. sharmstr
    try disabling the 3D viewer in Troubleshooting tab and try again.
    Every update has a changelog : OpenBuilds/OpenBuilds-CONTROL - which tells exactly what was changed, added and fixed :) - no need for luck, it says exactly what was worked on
    Real bugs also has to be reported here at the forum, or on git: OpenBuilds/OpenBuilds-CONTROL = we can't fix what we don't know about :)
    But this time round, it's not a bug, nor would an update help:
    From your screenshots there is nothing filled into the STEPOVER field: See its grayed out a bit? ( the 40 you see in there is called a placeholder: if you want to learn more about it: HTML input placeholder Attribute) click your mouse inside the Stepover field, you'll see its blank - you need to have values filled into all the fields. Placeholders are just guides to help you understand what a typical value should be.
    #3 Peter Van Der Walt, Nov 16, 2020
    Steveathome likes this.
