Following on port3 closed Thread
Discussion in 'OpenBuilds Forum Help' started by JCMR, Feb 8, 2025.
  1. JCMR
    JCMR New
    I am the guy that damaged his black box on the second try using a plasma my theory on why it happened its because i pull the trigger on the torch while my machine was connected and i think that could have make it short but my black box does connect for one time only but when i disconnect the usb and connect it a second time the black box send a port 3 closed error message . so its not totaled it works one time and it crashes, my cnc does work in that first "turn on " i believe this is the only part that got damage and i would love to know what part could be causing the error
    Have you tried a different PC as a test? Just to be sure its not a driver/os lock etc kind of issue
  3. JCMR
    JCMR New
    I have tried with an even better pc and same thing,fresh openbuilds software and latest win11 aswell ,all the power settings moved too
