Fusion 360 Issues with GRBL
Discussion in 'CAM' started by Rommell1787, Dec 1, 2024.
  1. Rommell1787
    #1 Rommell1787, Dec 1, 2024
  2. Rommell1787
    Downel pin operation using vcarve works fine
    #2 Rommell1787, Dec 1, 2024
  3. Misterg
    Misterg Veteran
    In your gcode you have:
    G28 G91 Z0
    I'm assuming that this isn't deliberate (if it is, then you need to set G28 in a safe position) and that you've selected G28 under the 'Safe retract' option in the post-processor dialogue (possibly the default). Change this setting to 'Clearance Height'
    It also looks like you're using the Autodesk GRBL post processor - There's an OpenBuilds optimised version available that many people use (but you need to have homing operational to use it) - Look for any of @David the swarfer 's posts - there's a link in his signature.
    David the swarfer and Giarc like this.
  4. Rommell1787
    Youre right. using the Openbuilds post processor works.
    The simualtion shows the tool going into the work but it actually lifts.
    Thank you
    #4 Rommell1787, Dec 1, 2024
    David the swarfer and Misterg like this.
  5. Rommell1787
  6. David the swarfer
    sadly the simulation does not know how to display the G28 nor G53 moves correctly. I think one could use the length set for the Z length to figure out how high to lift for a G53 G0 Z-5 move (and just do the same for a G28 move, or maybe use the G28 offsets for an exact move relative to home?), maybe one of the CONTROL authors wants to take this on as a Christmas challenge?
    I hope one does :) - my hands are sadly fully tied on a different OpenBuilds project :(
