Gadget Wrapping Rounding
Discussion in 'Control Software' started by John Raney, Sep 27, 2022.
  1. John Raney
    Hi
    I have set up a 4th axis addition on my Workbee. I input via the INTERFACE unit. I have not been able to make the gadget for Rounding Toolpath operate as expected. My Gagdet file is uploaded. I ask it to turn 360 deg but it will only turn 80 deg back and forth as seen in my accompanying video file. Do you think this is a post processor problem or a GRBL variable problem. If so what post processor should i use or what should i change in grbl. Would I use the control program.
    Thanks for your help.
    John Raney
    Could be either or both. See LEAD Lathe > in the thread Giarc shows his calibration as well as talks about Posts
  3. John Raney
    Will do thanks
