GCode Needs Altering
Discussion in 'CAM' started by Fintan Mitchell, Jul 3, 2022.
  1. Fintan Mitchell
    Hello,
    I'm attempting my first design and build of a telecaster style shaped guitar using Fusion 360. The design part has been grand and managed to generate the gcode. I uploaded the gcode to OpenBuilds control and setzero to a suitable location. I ran the Check Size button and it covered the cutting area but when I went to run the job the router just moved up the y-axis until it clicked the limit switch.
    Anyone got any ideas why this happened?
    Gcode is attached along with two photos of my setup.
    Thanks,
    Fintan
  2. Alex Chambers
    Checking the obvious questions - did you A) enable homing, B) home the machine before running the job?
    Also you specified G55 in your cam software - were you in G55 when you set the workplace co-ordinates system zero? - grbl controllers would default to G54 on start up.
  3. Fintan Mitchell
    Yea to both of those questions. I was at G54 but I got the following error: Warning: Invalid Work Coordinate System. Select WCS 1..6 in SETUP:postProcess tab. Selecting default WCS1/G54. That still generated gcode but it didnt upload to openbuilds control, that's why I changed to G55. If I change the grbl controllers to G55 will that sort this out?
  4. Alex Chambers
    Just ignore the warning - it's just telling you that, as you didn't specify a wcs in the Fusion cam setup it is using the default of G54. Or, in Fusion cam set up choose a wcs of 1. Without seeing your Fusion file I can see no reason why your file wouldn't upload to OB Control with G54 set - certainly just changing to G55 in your g-code wouldn't have made a difference.
    You could also change to G55 in your controller before running the file if the wcs is set to G55.
    Gary Caruso likes this.
  5. Fintan Mitchell
    Ok I'll change back to G54 and choose wcs of 1 and see how it goes, thanks for your help Alex.
