Hi, I’m using a BlackBox controller with GRBL and LightBurn. When I click Home, the laser moves correctly to the rear right corner (my X+ and Y+ limit switches are there). In LightBurn, I set Device Origin: Right Bottom, Start From: Absolute Coords, and Job Origin: Right Bottom. But when I click “Go to 0,0”, the laser moves all the way to the front left corner, not where it homed. I tried $10=0, G54, G10 L2 P1 X805 Y725 (LIGHTBURN CONSOL) — no luck.
Problem solved – I switched to OpenBuilds CONTROL, clicked “Set Zero” there, then went back to LightBurn and the coordinates changed to 0,0.
