grooves before and after tabs
Discussion in 'CNC Mills/Routers' started by mlowka, Sep 6, 2020.
  1. mlowka
    mlowka New
    Thanks for all your feedback- they help a lot. I have one problem left. There are grooves before and after tabs in the cutting material. I use cut2d- the plunge is set to 150, but it goes up fast- can this be the cause?
  2. mlowka
    mlowka New
    any ideas ????
  3. Christian James
    Christian James Journeyman
    To be honest, not sure what we are looking at. Need more pics to get it in context.
  4. Rob Taylor
    If it's plunging at one side of the tab, doing a full-depth cut, then retracting at the other side of the tab, that could absolutely be the cause. Try a ramp instead of a plunge, or move the plunges elsewhere to test.
    If not, it may be a system flex issue with the tool digging in.
  5. jeffmorris
    jeffmorris Journeyman
    The grooves are caused by the bit moving up and down while staying in one place.
  6. mlowka
    mlowka New
    I've tried to add spiral ramping but it extended cutting time from 16minutes to 1hour43min on one small element only. Not sure if I'm doing it right- never did it before. How do you add ramps properly without extending cutting times dramatically?
  7. Rob Taylor
    Ramping into a cut isn't the same as a spiral pathing strategy, it should only be an inch or two long and not significantly alter the length of the cut. You can choose to ramp in Z, or you can require an entry/exit strategy in X-Y, or whatever. The options are there in Fusion's operation options window. If you're not using Fusion 360, I'm not sure. Typically CAM algorithms and options are generally pretty similar though.
