have problem....
Discussion in 'General Talk' started by murex, Jun 15, 2023.
  1. murex
    murex New
    grbl error $j=G 91 G21 Z1000 FaN, what is,
  2. murex
    murex New
    grbl error $j=G 91 G21 Z1000 FaN, in the openbuilds
    Which controller do you have? BlackBox 4X or BlackBox X32?
  4. murex
    murex New
    Ho una genmitsu 4040 cnc non so che scheda monta
    CONTROL is for use with machines powered by Grbl or GrblHAL.
  6. murex
    murex New
    I already use this machine candle and it works quite well and it's grbl and I draw with aspire 9 with openbuilds for example it doesn't give me the possibility to maneuver any axis or the probe and I get that error
  7. Alex Chambers
    What controller do you have? Please post your grbl settings here.
    Candle support old versions of Grbl too. CONTROL has a cutoff of Grbl 1.1 (2016 and newer)
  9. David the swarfer
    seems to me you have not specified a feedrate
    OR
    there is a communication problem and the feedrate is being mangled, thus the return of 'FaN' which can be amngled version of 'NaN' for Not a Number, which happens when the USB fails to transmit the correct data, usually due to EMI. Read the EMI section of the documentation docs.openbuilds.com
    Alex Chambers likes this.
