Help for configuration of custom machine
Discussion in 'CNC Mills/Routers' started by l0v3byte, Dec 25, 2023.
  1. l0v3byte
    l0v3byte New
    Hello everyone,
    I need help with the configuration of my two new machines, an Acro System with custom dimensions with Neje n40630 laser and as a card a DLC32 v2.1 with TCM 2225 driver and a CNC Two Trees TTC 450 with dlc32 v2.1 with the spindle changed with the Genmitsu 775 at 20000 rpm 24v 15A power supply and when my order arrives also with the TCM 2225 drivers and AMB spindle (since the spindle support has the same dimensions 43mm).
    This is my first time using the OpenBuilds CAM and controller and I wanted to know how to import the machines parameters if I need to rewrite the firmware again and if it supports the machines motherboard.
    Since in a discussion a user said he used a TTC450 that uses the DLC32 v2.1 card, I thought about ordering the same one for Acro System too, but on OpenBuilds Control I didn't notice the card and not even esp32 which usually should also go on derivative cards.
    Can someone help me.
    Greetings to everyone and merry Christmas
  3. l0v3byte
    l0v3byte New
    Hi, tanks for your reply.
    For Openbuilds Control the board is like a fake arduino with ch340, but this is ok, jog spindle endstop etc work fine.
    But now I need help for the Openbuilds CAM for configuration macchine, on the section of machine is not present any custom macchine like the Openbuilds Control I try to use a similar cnc machine modifying the parameters?
    I hope you understand my English, is very long time I not speak or write in English.
    Cheers.
    Is the Acro from OpenBuilds?
  5. l0v3byte
    l0v3byte New
    No, for the TTC450
