Help me understand cutting direction relative to pocket cuts
Discussion in 'CNC Mills/Routers' started by Bryanw0705, Feb 24, 2025.
  1. Bryanw0705
    I am trying to understand why my pocket tool paths always do a mix of clockwise and counterclockwise cutting. Is there a way to ensure it always cuts in the directions want? The router rotates clockwise from top view cnc mounted, so for the cleanest cuts I’d think I want my tool paths to all also go clockwise so the wood is fed into the bit. If I were routing by hand that would always be the path I go, so trying to understand why pockets don’t seem to allow you to make them follow a single direction.
  2. Misterg
    Misterg Veteran
    What CAM are you using? It is usually possible to specify one way or the other.
  3. Bryanw0705
    OpenBuilds CAM
    I can specify climb or conventional in the options, but it doesn’t actually seem to change it
    https://github.com/OpenBuilds/OpenBuilds-CAM/issues/65 was a bug a while back, so if it came back thanks for the report, will reopen
