High CPU usage when
Discussion in 'OpenBuilds Forum Help' started by Artver, Nov 5, 2023.
  1. Artver
    Artver New
    Dear OpenBuilds forum
    I have issues with high CPU usage when idle or running from Open Builds Control.
    When I have homed the CNC it seems that there is an infinite loop using 100% of one core. This makes the UI really slow. I am on latest v1.0.370.
    Any ideas?
    /Martin
    Computer specs?
  3. Artver
    Artver New
    i7 7500U, 16GB DDR4 ram, Samsung 980 SSD
    The 7500u was a low end notebook CPU when it was released back in 2016. Being a low end notebook, probably lacks a decent GPU too so runs the 3D view in emulated graphics. Try a better PC
  5. Artver
    Artver New
    An easy answer, but fair. I will buy a new computer. Have found a cheap i5 12500H. Should be a lot faster. Do you know if there are some recommended specs? I can't find any. I would like to know if I can expect this to be sufficient.
    Specs wise, the 3D viewer uses OpenGL so a GPU help. Cheaper PCs has to offload GPU workload onto the CPU. More RAM is always good. If it can run Fusion360 well, it will do CONTROL and other CAD/CAM/Host application too
