homing issue
Discussion in 'General Talk' started by gilltee, Feb 7, 2021.
  1. gilltee
    gilltee New
    i've searched the threads and have done everything I can, check wiring, wheels, changed out limit switches I'm thinking it has to be something in my settings.
    When homing my lead 1010 Z axis moves, hits the switch and debounces then Y starts moving hits the switch but just stays stuck there.
    I have attached my settings file, I have toggled Limit switches installed on and off also toggling hard limits on and off. can someone please help
    Edit: btw I am using standard run of the mill limit switches in an NO wired configuration, my wiring at the switch is Com/Black NO/White then at the blackbox GND/Black Sig/White not that that should make any difference right?
    #1 gilltee, Feb 7, 2021
    Please make a video showing what happens?
    When it gets "stuck" does the motor for that axis stop, or does it keep ramming into the switch. If it stops, it may be crossed wiring between X and Y (make sure you know which axis is which, and that the correct port is used to plug in that axis's switch)
    Any alarms onscreen?
  3. gilltee
    gilltee New
    Hi Peter,
    Thanks for your prompt reply mate. I have attached a short video of my issue in action. Imwuite certain i dont have the axis' mixed up as they trigger all correctly as you see inthe video.
    When i first encountered this issue the motor actually kept ramming until i hit abort but somehow that issue has gone or I've changed a setting I cant remember!
    Thanks!
    Confirmed the wiring of the switches is correct.
    Right so at the point where the Y limit is hit, its correct, Y should stop moving first.
    But at that time X should still be moving - it should first contact BOTH the X and Y switches fast (called Homing Seek) - only once both are found, it should back out of the switch and come back in slowly for the final accurate homing operation (called Homing Feed - see gnea/grbl )
    So on yours, When it hits Y, what does X do? (Y looks fine, X is current suspect)
    When you hit Abort the error that comes up is "Homing fail. Reset during active homing cycle." - which Means Grbl hasn't given up - it was still trying to move the X axis toward the X Switch - so was it still moving at that time? If not, lets see why not. If you didn't abort it would have eventually alarmed with "Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases." if the X axis was not moving toward the switch
    Summarised:
    - When you kickoff homing, after Z, both X and Y should start moving
    - Whichever is nearest the switch hits it first, and waits for the other to catch up.
    - Once both has his the switches the first time, they then back off and then does the rehome step.
    Are you sure the X axis jogs the X motor?
    Flashed any custom Grbl builds that may have custom homing sequences?
    Default homing sequence I described above is defined in stock Grbl config: gnea/grbl
    #4 Peter Van Der Walt, Feb 8, 2021
  5. gilltee
    gilltee New
    So on yours, When it hits Y, what does X do? (Y looks fine, X is current suspect)So
    So as soon as the Y switch gets switched, X does nothing. Shouldn't Y do the same thing as Z where it hits the switch and then backs off it a little? If so Y isn't doing that. Yes you're right mate after a few minutes the alarm state is triggered
    Summarised:
    - When you kickoff homing, after Z, both X and Y should start moving If both X and Y are meant to start moving as soon as Z is triggered then thats not the case here. Only Y Starts moving as you can see in my video.
    Are you sure the X axis jogs the X motor? I'm 100% sure X axis jogs the X motor, as this is why im scratching my head. I am able to manually move my spindle around my entire CNC bed and when the switches are triggered faults will come up as they should
    Flashed any custom Grbl builds that may have custom homing sequences? I havent flashed anything myself, however since you've mentioned that. My brainboard was swapped over at makerstore.com.au due to it being DOA. I am unsure what the process is with the brainboards at the suppliers end whether they come preflashed with stock firmware or whatever else.. you may know more about this than I do :)
    Default homing sequence I described above is defined in stock Grbl andonfig: gnea/grbl[/QUOTE]
  6. gilltee
    gilltee New
    [17:05:26] [ $I ] [VER:1.1g.20181112:LEADMACHINE1010]
    [17:05:26] [ $I ] [OPT:V,15,128]
    [17:05:27] [ connect ] Firmware Detected: grbl version 1.1g on COM4
    that is the firmware that I'm currently running. I did speak to the mob which whom I purchased the blackbox from they said that there wasn't any funky custom firmware revisions flashed onto this new brainboard that had been swapped in.
    I am really stumped for solutions, have had spent a week now sifting through these forums and online for a fix for my problem. Today just for shits and giggles I went over all my wiring just to quad dripple check that I haven't wired anything incorrectly. This is my first CNC and even though I am new to all this I am a qualified electrician. Electricians can overlook their wiring of course! But I am quite confident I have wired everything correctly. I have even gone to lengths today as to seperate the limit switch wiring so it is physically located as far from power cables as possible to avoid any induction that may arise from them and snapped on some ferrite cores onto them just to eliminate that from the equation. (I didn't think that could be the issue as the switch for Z was actually ran in the same drag chain as the power cables and that worked the way it's suppose to as evident in my video)
    Really hope you have something else for me to try :([/QUOTE]
    But prior to it hitting the Y switch, is X moving?
    It really should. After the failed home, can you jog X? (Driver not in protection mode?)
  8. gilltee
    gilltee New
    in the homing sequence, prior to it hitting Y, X is not moving
    so after it hits the Y, can I jog X without removing the alarm? if thats what you're asking no I cannot
    once i remove the alarm then yes I can move X fine
    #8 gilltee, Feb 9, 2021
  9. Peter Van Der Walt
    Yes once alarm is cleared. Super weird.
    Try
    1) reset EEPROM ($RST=*) there is a button on the Grbl settings tab
    2) Reflash grbl from Wizards and Tools > Firmware Flashing tool
    3) reconfigure parameters - dont load a backup in case something is off, set it up from scratch please.
    You are using an OpenBuilds BlackBox right?
    #9 Peter Van Der Walt, Feb 9, 2021
  10. gilltee
    gilltee New
    I have followed your instructions above, reconfigured all the parameters manually again and not from a backup.
    hate to say this but am experiencing the same issue :(
    yes mate, I am using an OpenBuilds Blackbox.
  11. Peter Van Der Walt
  12. gilltee
    gilltee New
    I'll give it a go. Thanks very much for your assistance mate
  13. gilltee
    gilltee New
    hey mate one more thing. Have you got a picture of what the brainsboard is meant to look like? more specifically where the jumpers on the brainsboard should be located on all the jumper pins.
  14. Peter Van Der Walt
    See docs.openbuilds.com/blackbox
  15. Bryanw0705
    did this ever get resolved? Same issue here, was working just fine then it started
  16. Peter Van Der Walt
    Describe your issues exactly so we can work with the exact problem and the specific nuances of your situation please
  17. Bryanw0705
    The machine was shutting down on y limit activation. I found that the wire was somehow pinched as releasing it addressed the issue
